Thread: Wheel fit question 1966 911
    Senior Member bobm's Avatar
    Aug 2011
    Northern California
    I am sending my 4 1/2 fuchs to Harvey (thanks Harvey) for refinishing and a friend was going to lend me his 5 1/2 X 15 deep fuch's with 205- 60 X15 till mine are finished. I bolted on the wheels and the rears are fine but the fronts just bearly rub on the struts. I tried a wheel spacer but not enough thread left on the studs. Short of putting on longer studs (don't want to) is there a quick temp fix. I have heard of guys using deep 6's but must require some change.The wheels look nice on the car and the xtra meat would be nice.
    Thanks for any suggestions.
    Bob M
    Nor Cal
    304014
    Dec 2008
    Woodland Hills, CA
    I run 15x6 on the front of my SWB...no rub.
    Dec 2010
    Tulsa
    I used a 6mm spacer - it barely clears the strut (about 8mm), and still has enough thread to work on the studs. However - the correct solution is a 10mm spacer, and longer studs.
    Yeah, a 7mm (or 6mm) spacer is the right way to handle the front with wider wheels. BTW, those 4.5" Fuchs still fit fine on the rear with a 22mm turbo spacer and longer studs. The increased track makes the car feel more predictable and the wheels wells look more balanced.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. 1966/1967 Front Cross Panel Question
    By Toffynose in forum Technical Info
    Last Post: 11-08-2013, 02:01 AM
  2. 1965/1966 Door Lock Post Question
    Last Post: 11-07-2013, 07:55 AM
  3. Vintage Momo Steering Wheel Question, Identify this wheel
    By rennwagen in forum Technical Info
    Last Post: 08-28-2012, 04:25 PM
  4. FS- beautiful 1966 steering wheel
    By jojogto in forum For Sale: 911 Parts
    Last Post: 12-02-2009, 02:49 PM
  5. Replies: 2
    Last Post: 05-08-2008, 09:35 AM
