Thread: Zenith Rubber Manifold Sleeves?
    I was looking through some parts lists today and saw a part called "Rubber Sleeve for Intake Manifold" part number 999-703-076-50 (now NLA apparently). I saw a picture of this part the other day in the "For Sale" forum still attached to a set of Zenith manifolds. My question is, what's the purpose of this piece and does it hurt not having them installed? Should I try and find a set for my Zenith manifolds? Thanks in adance,
    Stretch
    The PET describes them as a rubber grommet - rather than a sleeve- and 999.XXX. XXX.XX numbers are usually standard hardware items such as nuts, bolts and washers.
    I have never seen them fitted to a manifold but would be interested in seeing a photograph.
    Here's a picture I took from the "For Sale" forums showing them installed in the holes between the intake necks(?). There are 4 in total with 2 per manifold. If you look atthe PET it appears this is where they go so I think the pictures are correct.
    StretchName:  grommet.jpg
    Dec 2004
    SE Michigan
    You pass the spark plug wires through them.
    Keeps the jackets from wearing through and the wires from grounding to the manifold.
    Bill G.
    EarlyS #718 | RGruppe #437
  1. WTB: Need right side Solex manifold
    By Frank Beck in forum For Sale: 911 Parts
    Last Post: 11-30-2013, 04:40 AM
  2. FS manifold for weber 40
    By advtracing in forum For Sale: 911 Parts
    Last Post: 11-12-2012, 01:24 PM
  3. WT Swap PMO Manifold
    By Fishcop in forum For Sale: 911 Parts
    Last Post: 09-16-2012, 02:39 PM
  4. WTB: Engine case locating sleeves 901.101.145.00
    By cscrogham in forum For Sale: 911 Parts
    Last Post: 06-03-2011, 09:29 AM
