Thread: Auto X Tire Pressures
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    Question Auto X Tire Pressures
    Auto X Tire Pressures?
    Long course, NE weather in 2 weeks!, non competitive ( me = fun ) dead stock 73.5
    any suggestions will be welcomed
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    I'd start at 28/30 and see what happens.
    It's easier to let air out than to put air in ...
    -Marco
    TLG Auto: Website
    be sure and check it after first run group too ,pressure will be much higher at temperature. Nitrogen lessens this fluctuation btw. S
    Lower pressures provide better breakaway (also helpful in the rain), higher pressures provide better feel - in general. But recommended tire pressure really depends on the make and model of tire.
    Most street tires like 32-38 psi typically. Marco's suggestion to start at 28/30 is good for the track. In autocross the pressures only rise about 2 pounds in cool weather over a 60-second course, so a starting point of 31/34 may work better for your use. Again it depends on the tire (and the driver to some extent).
    Randy Wells
    www.randywells.com/blog
    www.hotrodfilms.com
    Early S Registry #187
    Jul 2006
    Pine Bush NY
    Thanks for the input!
    Lime Rock suggested the cars arrive with 45 and then air down, but if I drive there with that much air ( especially in the front ) my eye balls will not be able to recover in time to any driving.....
    Ron
    1973.5 911T
    1974 BMW R90/6
  1. FS @ AIC Auto - '69T
    By Cal in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 03-25-2013, 09:19 AM
  2. Replies: 2
    Last Post: 10-09-2012, 02:47 PM
  3. Saratoga Auto Museum Spring Auto Show Sunday May 18th
    By Perry911 in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 04-17-2008, 11:38 AM
  4. Tire pressures for 205/60HR/15 ??
    By Type911 in forum General Info
    Last Post: 10-30-2005, 09:36 AM
  5. Pressures
    By AndyR in forum Technical Info
    Last Post: 04-05-2001, 07:39 AM
