Results 1 to 10 of 12
Thread: Rechroming early door handles made from Zamac (zamak)
    Semjon Semjon's Avatar
    Jun 2005
    Groningen, Netherlands
    Hi everyone, while in the process of building up my car we ran into the door handles which are really pitted.
    My idea was to rechrome them but my restore guy gave me a warning that the material of which the handles are made is not really suited for this.
    They are made from Zamac (or Zamak) which is a mixture of tin, lead and copper which could be casted at a relatively low temperature.
    Over the years these materials reacted to eachother (electrolyse) which causes blisters and pitting.
    It seems it doesn't matter how you prepare them or treat them, the blisters will keep popping up.
    Is there a suitable sollution to this? Are there reproductions made from other material (not plastic )
    We have a wild idea to scan them in 3D, make a mould and cast them in brass but that's quite costly...
    Regards, Semjon
    Early 911S registry member #1391
    Built '65, MY66 911 in total restoration
    Jan 2011
    Sunny Southern France
    Hi!
    IMHO, if you have your original parts cleaned, and plated in the proper way, you should end up with like NOS handles good to go for the next 40 years...
    Just google "zamak chrome plating" (I did) and you'll find tons of informations about it. Looks like there is a proper way to prepare zamak, for copper plating, then nickel then chrome which involves a lot of activating/passivating steps...
    Just my 0.02€!
    Olivier.
    Jun 2005
    Hi Olivier, thank you for your reply!
    I indeed searched a lot and found indeed the process you describe. However many companies don't guarantee the outcome of the plating and warn about the blisters that can come back over time.
    Since the whole preparation and chroming of the handles is also time consuming and costly with a non guaranteed outcome I'm searching for a good alternative.
    The Netherlands
    Hi,
    It's the same material as the two front horn grills and what I understood is that the deep pits are filled with solder (50/50, OR 60/40 ?) and then onto the plating process. Probably Alan of Canford Classics will be able to tell you more.
    Rgds, Cees
    Is there a reason for you that you want to restore your 'original to the car' handles? If not, why not source a set of pit free handles?
    Richard
    Jun 2005
    Cees, thanks for the tip! Will look into it.
    Richard, since all the handles are made from zamac they all suffer this problem. Some have less pitting, some have more pitting but a perfect pair I haven't been able to source.
    Thanks again!
    Quote Originally Posted by Semjon View Post
    Thanks again!
    Semjon, they are definitely out there. That is how I got mine. Try dry states like AZ and NV.
    Richard
    Nov 2006
    S. F. Bay Area
    I have my ('67) entire cars' worth of chrome at the platers now. They are in Oregon. I have seen their work on other Porsches and they sure seem to know what they are doing judging by their results. If interested I can post their info here on Tue (out of town). Brian
    Brian
    S Reg #1032
    Zamak/Mazak - Zinc based die casting alloy.
    mainly Zinc with additions of Aluminium, Magnesium and Copper.
    Unhappily no Lead or Tin.
    Soft Solders just don't work on Zinc based alloys as the contact angle of the molten solder is just to high and it won't wet the surface.
    The problem with all die casting alloys is that they tend to be 'eutectic' compositions which means that they have a very short freezing range.
    This helps with porosity and productivity but makes it very difficult to braze/weld this type of material as it goes from completely solid to completley liquid in about 5 degrees.
    It may be possible to heavily Copper Electroplate and then re-polish but this tends to deal with relatively small pits and is quite expensive.
    Yout could strip them, fill them with a metal loaded filler and vacuum metallise but they wouldn't be as durable as the originals.
    Dec 2004
    SE Michigan
    Quote Originally Posted by Silverbullit View Post
    Yes, please post info.
    Bill G.
    EarlyS #718 | RGruppe #437
  1. FS: Early Door Handles
    By prez! in forum For Sale: 911 Parts
    Last Post: 12-14-2013, 09:25 AM
  2. FS: Set of Early Chrome Door Handles & Misc Early Parts
    By sebring66 in forum For Sale: 911 Parts
    Last Post: 09-10-2013, 04:23 PM
  3. FS-NOS early door handles 67 and earlier
    Last Post: 06-27-2010, 10:05 AM
  4. FS-nos and used early outside door handles
    Last Post: 10-28-2009, 09:05 PM
  5. FS - Early 911 Door handles
    By jass in forum For Sale: 911 Parts
    Last Post: 02-28-2009, 08:33 AM
