Results 1 to 2 of 2
Thread: 1965 911 keys numbers
    Jul 2010
    LE MANS
    I recently found a 911 purchase order from french dealer SONAUTO dated july 1965 where the keys numbers are mentioned :
    Doors and contact : FL 1162
    glove box : CC 960
    Anybody has other informations about those numbers ?
    FAP, those are the cut for the key. If you gave those numbers to Tony the key man, he could make exact fitting keys for the old locks.
    (That is the code found on the kardex, and stamped onto the original keys) A locksmith with the old books might answer what the position of the cut would be.
    Zundscholb-Nr: Ignition switch number, FL (+4 digit) Schlussel-Nr: Key number /glove box CC (+2 digit) I see your reference has a 3 digit for this key.
    Also there is a code for the 5 pin Locking ignition and the 4 pin non-locking ignition: longer key and shorter key.
    Bob
    Early S Reg #370
  1. FS 1965 911 coupe matching numbers for restoration
    By 911r67 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-18-2012, 10:58 AM
  2. How many keys should an original car have?
    By vricardo in forum Technical Info
    Last Post: 06-03-2009, 11:16 AM
  3. Steel keys vs brass keys?
    By bob tilton in forum General Info
    Last Post: 04-16-2009, 11:15 PM
  4. VIN numbers and dash rail numbers
    By davidppp in forum General Info
    Last Post: 08-21-2007, 09:01 AM
  5. '72 Keys
    By Lee in forum Technical Info
    Last Post: 05-10-2007, 07:10 PM
