Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: WTB: 1968 T engine
    Senior Member nvr2mny's Avatar
    Mar 2012
    Kansas City
    WTB: 1968 T engine
    Looking for a '68 T engine, preferably complete. Needing a rebuild is ok. Thanks...
    Doug
    Banned
    Nov 2004
    Scottsdale, AZ
    I have a complete one, sans smog pump. Been sitting 20 years.
    PM sent.
    Mar 2012
    Kansas City
    Frank, Replied back. Posting the info here too. VIN# 11870138. Per COA; Production Date 12/15/1967. Engine# 2080535. Also need - Trans# 2280485 (901/03).
    Dec 2008
    Woodland Hills, CA
    Would a 68 T motor come with a smog pump? I thought 68 Ts were RoW only.
    Banned
    Nov 2004
    Scottsdale, AZ
    Technically it was just a "911" and the U.S.-delivered cars had smog pumps. The '68 911S was RoW.
    Dec 2008
    Woodland Hills, CA
    I believe the T and Normal were different motors. The T had a 109 hp and no smog pump because it was a RoW production. The normal shared the same engine with the L and was rated at 130 hp and both were equipped with the smog pump.
    Mar 2012
    Kansas City
    Per the information I have been able to find off vin verification it was an RoW vehicle. I am not aware of the differences of a T vs Normale engine(s) so any and all info is welcomed.
    I think Frank is correct, 911T didn't make it directly to the US In 1968, just the 912, 911 Normal and 911L.
    I believe the 911T ROW would have the non-counterweighted crank, milder cams, no pulley on the drivers side chain box for air pump, weber 40IDT carbs and no vacuum retard distributor. From the engine number you posted, you are looking for an aluminum engine, which is good and bad. Aluminum cases are good but hard to find and expensive.
    http://www.early911sregistry.org/for...+aluminum+case
    You might check this thread and see if someone has your engine
    http://www.early911sregistry.org/for...Engine-Build-s
    Banned
    Nov 2004
    Scottsdale, AZ
    Sorry, I assumed Doug had a U.S. car until I saw the VIN and engine#. 901/3 is in fact RoW and as Casey said, difficult to come by. The complete motor I have is a 901/14.
    I'll keep digging.
    Dec 2008
    Woodland Hills, CA
    I thought that this what I was saying to begin with...
  1. FS: 1968 911 with 67 911 S engine
    By georgepvalerio in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 01-04-2013, 03:17 PM
  2. WTB 1968 engine
    By rhart in forum For Sale: 911 Parts
    Last Post: 11-14-2012, 08:30 PM
  3. Replies: 8
    Last Post: 09-01-2012, 05:47 PM
  4. Fleebay Engine: 1968 Porsche 911S Engine 901/02 Weber IDS 40 Carbs 911 S Motor
    By Doc72 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 08-31-2012, 07:09 AM
