Results 1 to 8 of 8
Thread: LWB- Does the front lower valence need to be dropped to ..
    Apr 2011
    N.Calif., south of SF
    ... remove the front bumper strip? This is for a 73 911.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Haasman View Post
    If you mean the front bumper to body seal, yes you do.
    Jim
    Apr 2011
    Sorry maybe not too clear- I want to replace the front rubber rub-strip across the front of the car.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Aug 2009
    SF Bay Area
    Actually, doing just about anything to the front bumper requires removal. It is quick and easy and then you have access. It can be put on a bench and you can work in a comfortable position, as well.
    Jim
    Apr 2011
    Thanks Jim. Good suggestion.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Absolutly what Jim said........
    Jan 2011
    DFW TX
    Just the rubber and no over-riders? Then you can do it on the car... for the S trim the ends have screw studs that go thru the bumper, don't know about narrow trim. Remove the nuts and peel the rubber trim off the aluminum base. To re-install bend the rubber trim over on itself to get the rubber lips to spread, and apply to the aluminum base. Loads of fun to do, but less hassle than realigning the bumper.
    Apr 2011
    I've got a 73 with the big black baby buggy over riders .... so I will replace the them and the individual wide decor pieces with an S one-piece. So ... after the BBBB over riders are taken off I won't have to remove the front lower valance?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  1. Opinions wanted--front lower valance
    By Frankr in forum Technical Info
    Last Post: 04-11-2014, 08:10 PM
  2. FS: 76 Turbo Front Spoiler + Valence
    By Shaun 69 E in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 01-23-2014, 04:52 PM
  3. WTB: 68 lower / front dash in good shape
    By Mdezeeuw in forum For Sale: 911 Parts
    Last Post: 09-05-2013, 09:13 PM
  4. FS: NOS OEM front trunk latches (upper/lower)
    By porschepartguy in forum For Sale: 911 Parts
    Last Post: 01-28-2013, 09:22 AM
  5. How to un-lower my front end
    By oscillon in forum Technical Info
    Last Post: 04-14-2011, 08:09 PM
