Results 1 to 8 of 8
Thread: Fuchs wheel info needed
    Apr 2012
    Simi Valley Ca
    I bought my 1969 911S in 1974, and the original wheels were long gone, replaced by chrome rims. The car has been in storage for 36 years, and last I checked, the Porsche Fairies had not restored the wheels to the original Fuchs.
    Searched the forum, but could not find much info. I guess I am looking for the 15X6 "Deep Sixes", does anybody have the specific P/N that I should be looking for? I understand that these wheels only came on the '69 and "70 "S"cars, so I pretty much decided that I am not going to find a set of date matching late '68 early '69 wheels. I believe my car was a Feb. or March '69 car, as it was sold in Hollywood in early May.
    Also, if I can find a set of 15X7 for the back, what P/N should I be looking for? I have seen some but they seem to have too much offset. So what exactly am I looking for here. Any clearance problems?
    If anyone out there has a set of these wheels, and wants them to go back on a 69S like they were intended to be on, and not some lowered VW Bus, please PM me.
    Bob B
    Jul 2011
    Chicago Area
    My '71 targa came with deep 6's as original equipment delivered 11/70.
    Mike Fitton # 2071
    2018 911S Carrera White
    Dec 2003
    West Los Angeles
    I did the same for a client's '69S last Fall. Be patient. It took me over 3 months but I was able to find the correct date match wheels.
    In your case, if the car was built in March, 1/69, 2/69 or 3/69 would be "date matching."
    techweenie.com
    This link has a quick list of early Fuchs p/n's, http://cprclassic.com/reference/fuchsalloys.html. I think you're looking for 901.361.012.06.
    Harvey Weidman is the guy to see about sourcing and or restoring some wheels. Not cheap or fast but does fantastic work but it sounds like time might not be an issue in this case.
    I placed a wanted add here for wheels for my 69E and had them shipped straight to Harvey for restoration. Almost too nice to put on the car!
    If you want 7s your best bet is 7Rs which have the extra inch on the inside but look like a deep 6 from the outside. Real 7Rs are crazy expensive but again Harvey can build you some from deep 6 cores or there some new replicas available. You will need some spacers to get them to work properly without rubbing unless you have flares.
    You will also see chat about deep 6s with and without "hearts". The early wheels which suit your car have "hearts" which are really just a small bump near the valve stem.
    Jeff Eelkema
    69E (project)
    S Reg #1431
    Aust TYP 901 #132
    Apr 2012
    Simi Valley Ca
    Thanks to everyone for the replied. I have talked to Harvey about a set, and told him I have a year before I may need some wheels. Should I insist on 1-69 2-69 3-69 date code. How important is that?
    Bob B
    Aug 2011
    New York
    Importance depends on the COA from Porsche. If the rim type does not match the COA, then the date code will not matter.
    E Sully
    1973.5 911T
    Dec 2003
    West Los Angeles
    That would be true if Porsche had any other 15 X 6" wheel made in that timeframe. AFAIK, they did not.
    Edit:
    On the other hand if the CoA says steel wheels, you're correct...
    techweenie.com
  1. info needed on car purchase
    By steve shea in forum General Info
    Last Post: 05-28-2014, 08:46 PM
  2. Replies: 14
    Last Post: 07-22-2011, 04:09 PM
  3. Info needed please for insurance
    By advtracing in forum General Info
    Last Post: 02-12-2010, 03:17 PM
  4. Weber 46 info needed
    By BURN-BROS in forum Technical Info
    Last Post: 06-11-2008, 06:10 PM
  5. engine info needed
    By wsh in forum Technical Info
    Last Post: 02-14-2005, 02:36 PM
