Results 1 to 9 of 9
Thread: Question on Type of trim under the rear quarter window
    I purchased two different types of trim which locate under the rear quarter window. The first three pictures is the trim that got holes to put the screw to attach with the rear quarter panel. The last three picture is the trim that no hole but it has a pin underneath to attach with the quarter panel. My question are which type of trim that correct for my 1969? and what are the different between these two types of trim?
    Thank you
    I believe the trim with pins are for 67 and earlier cars. I think 68 and later cars are secured with screws and the trim is aluminum rather than chrome plated as the earlier pin type. Do not see your pix.
    Forgot to attach the picture, Here are the trim with hole that secured the rear quarter panel with screw
    picture for the trim type without hole that secured the rear quarter panel with pin underneath
    The trim with the holes in it would be correct for your 69.
    Quote Originally Posted by 303462 View Post
    Thank you very much
    Atlanta, GA
    How is the trim w pins secured?
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    That trim is similar to 73 targa rear quarter trim held in place with spring clips attached from underneath the fender
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Chrome trims were used up to 67 these were held on with speed clips similar to what holds the rear script on the lid.
    HTH
    Alan
  1. Rear Quarter Window trim?
    By Milou in forum Technical Info
    Last Post: 10-26-2013, 11:29 AM
  2. Rear quarter window trim
    By leedurrant73 in forum General Info
    Last Post: 08-30-2013, 09:53 AM
  3. FS: 65-67 Rear Quarter Window Trim
    Last Post: 02-13-2011, 10:02 PM
  4. Rear quarter window and Door trim
    By jennetd in forum For Sale: 911 Parts
    Last Post: 06-11-2010, 05:03 PM
