Results 1 to 7 of 7
Thread: WTB: 69-73 911 Wiring Harness plugs for signal and wiper switches.
    Early 911 Fan, 914-6 Owner Martin Baker's Avatar
    Jan 2005
    Looking for the wiring harness connectors for turn signal and wiper switches from a 69-73 911 harness. I have a conversion steering column in work for my Vintage Race car, a 914-6 conversion. This is really the last piece of the puzzle to make it a believable replica. Have the switches, looking for the connectors, to hard wire it. The connectors with 3-4 inches of wire on each would be ideal. Thanks in advance.
    Martin
    Here it is Laguna last weekend with HMSA.
    HMSA and CSRG Member, THE Premire Vintage Racing Clubs! See you at the TRACK !
    See me GO! https://www.youtube.com/watch?v=pPjikgbTyqw
    Aug 2007
    Phila Pa. area
    ends
    Do you need the male or female ends?
    Mike
    Jan 2005
    The car side, so female. I realize this involves destroying two portions of a 911 wiring harness. I have several 914 type wiring harness portions I have saved out of wrecked, or parted out cars. Hoped someone had the same from a 69-73 911.
    Martin
    Are you needing the round bulkhead connectors?
    Jan 2005
    Yes, I am by no means an expert on the 911. I have never seen this harness, only the switches. I want to hard wire this column past the connectors, so if I ever need to replace a switch it will be plug and play as the engineers designed it.
    Martin
    I have some old 911 t/s switches with the round male 6 pin bulkhead connectors, but I thought the 914/6 used the rectangular 12 pin connector plugs.
    Jan 2005
    Have what I need located, and you are partially correct. Thanks Mike!
    I did some research in my own garage, had a close look at my 914-6 (Actual, not the replica), the wiper switch uses the same 6 pin plug as a 911, however, the signal is a 12 pin like you mentioned. Obviusly the 911 parts are much easier to locate, and I am converting a four cylinder car, so I want to be able to have plugs for ease of maintenance, should I ever need to change a switch in the future. I could simply hard wire the switches, but once I have wired/installed, the last thing I want to have to do is remove 20-30 spliced wires. For the record, both switches in a 914-6 are different than the 911 by part number( and other small details in wiring), and at this point in time are nearly impossible to find. Found a used signal switch for $475.00. I simply would not pay that for it, being a replica column conversion. I have $175 in two switches and nearly perfect original clam shells. All three came from a 911 parts stash.
    Martin
  1. FS: turn signal and wiper switches from a '72
    By 911scfanatic in forum For Sale: 911 Parts
    Last Post: 06-20-2014, 02:44 PM
  2. Remove wiring harness - 67 firewall plugs
    By mbruen in forum Technical Info
    Last Post: 05-12-2013, 03:37 PM
  3. SWB 911/912 Turn Signal & Wiper Switches & Housing 65-67
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 01-08-2012, 05:37 PM
  4. Replies: 0
    Last Post: 11-04-2011, 02:00 PM
  5. FS: SWB 911/912 Turn Signal & Wiper Switches & Housing 65-67
    By rennmark71 in forum For Sale: 911 Parts
    Last Post: 10-07-2011, 03:50 PM
