This was a fender that I bought when I was planning on doing a center-fill tank. I had the gas filler flap opening professionally welded shut. Plans changed, so the fender is up for sale.
Started with a pretty nice original fender which was stripped to bare metal. The headlight and turn signal boxes are in great condition. It did require a small repair near the bumper mating flange, a small repair where the inner brace trapped water and there was some pitting near the bottom where the S trim trapped moisture.
Fender was stripped to bare metal and sealed with DP90 epoxy primer. Needs a skim coat of filler and is ready to paint.
$325 obo
