Thread: Steering wheel removal
    Mar 2012
    Dumb question - do you need any special tools to remove the steering wheel from a '66? Thanks in advance, b
    Apr 2008
    Virginia's Blue Ridge
    Nothing special, but after all these years the nut can be tough to break loose. An impact driver will make short work of it and I'd highly recommend using one.
    Senior Member VA_alfa's Avatar
    Jan 2013
    Shenandoah Valley
    Bruce,
    You will need a 27mm socket and ratchet. If the wheel has not been off in a while, you may need an impact to break it loose. Leave the nut on by a few threads, when you start working the wheel off by pulling one side then the other, it will pop loose. The nut will keep the wheel from hitting you in the face. . Don't lose the washer on the front or the spring on the back.
    Alex in Virginia
    Looking for:
    ward to driving my car!
    Early 911S Registry # 2863
  1. Steering wheel nut removal
    By BrentF in forum Technical Info
    Last Post: 04-24-2013, 10:20 AM
  2. Steering wheel removal??
    By Zuffenhausen in forum Technical Info
    Last Post: 11-27-2009, 12:15 PM
  3. steering wheel removal?
    By 300814 in forum Technical Info
    Last Post: 11-01-2009, 10:40 AM
  4. Steering Wheel Removal
    By roray in forum General Info
    Last Post: 05-09-2009, 02:52 PM
  5. 73.5 steering wheel removal....help!!!
    By KJensen in forum Technical Info
    Last Post: 10-26-2005, 01:00 PM
