Results 1 to 10 of 13
Thread: FS: Koni Struts
    FS: Koni Struts
    New to this board. Actually was referred by one of the 914 World members.
    I recently bought a build in progress of a nice 914. The PO wanted to flair the car and put a 911 front end in, but I'm not going to take that path.
    I have for sale a set of Koni Struts, part number 911.341.079.16
    Also two Koni inserts and threaded caps that seem to be in very fine condition. I turned them all the way closed and can't pull up the shaft and when set at 3 turns, they seem to give me plenty of resistance when I press down quickly on them.
    The struts are naked - meaning they do not have any wheel components on them.
    $850.00.
    Len
    PM sent. Thanks.
    Len,
    This is a 'stated price' forum... if it's here and not a link to ebay then you must state a price....ASAP
    http://www.early911sregistry.org/for...efore-you-post
    Len,
    Sorry Admin, didn't realize that.
    I'm not a 911 person, but I was told they should bring around $850.00 for the set (struts and inserts).
    So that's what I'd be looking for.
    Hi Len.
    I am interested and sent you a private message. Could you post full-length photos of the struts? And please confirm the bolt spacing. Thanks.
    Alex
    Quote Originally Posted by neunelfs View Post
    Hi Len.
    Alex
    911 SC A-calipers fit these. I have a pair of them that came with, along with a rebuild kit (for the calipers). Center to center, the holes for calipers are about 3.25", 3" inside to inside edges.
    911SC a-calipers fit - have a set of those also w/rebuild kit that could go with if needed
    Holes measure about 3.25 inches center to center - 3 inches inside edge to inside edge
    If you are interesed in these, I've listed them on ebay.
    Pin type or pinch type ball joint?
    -Marco
    TLG Auto: Website
    Quote Originally Posted by Mr9146 View Post
    Pin type....
  1. Replies: 3
    Last Post: 03-26-2014, 03:41 AM
  2. Replies: 3
    Last Post: 09-15-2013, 11:13 AM
  3. FS: Koni Struts
    Last Post: 07-14-2013, 02:44 PM
  4. FS: '73 S Koni Struts
    By 913 in forum For Sale: 911 Parts
    Last Post: 04-23-2013, 05:06 PM
