Results 1 to 10 of 12
Thread: CV joint(s) questions
    Apr 2011
    N.Calif., south of SF
    It seems the outboard CV joint is bad on the 73 911, that has 104k miles on it. I am trying to determine what is best to do. What is the recommendation?
    -Do I find a Lobro (OEM supplier) complete half-shaft replacement figuring if the outboard is bad, it would be time for the inboard? Somebody is supposedly selling a complete unit (inboard and outboard CV joints, dust boots etc) for about $100 more than just one CV joint.
    -Or simply rebuild each one as I go?
    I do want to stay original as possible. I've read multiple threads and rebuilding the CV joints.
    Your advice/experience and potential suppliers would be appreciated.
    Thanks.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Feb 2010
    San Francisco, CA
    Timely thread.
    I've done it both ways. Rebuilding the CV is a MESSY job. Not especially hard to do, just messy. I had a split boot on the passenger side and I pulled the assembly and rebuilt. Then a month or so later, I had the same thing happen on the drivers side. For that one I opted not to rebuild and just throw a new one on. They are cheap enough that I didn't think I wanted to risk a failure on a rebuilt unit.
    K
    E911SR & RGRUPPE
    '73 S Coupe #306
    Apr 2011
    Interesting .... so Kent where did you get your new from?
    I dont mind the dirty work, but after adding up the parts it came out better to buy a complete shaft, depending on the price of course.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Feb 2010
    San Francisco, CA
    I bought the complete löbro axle from Parts Heaven last year. Jim can get one for you also.
    If you decide to go the rebuild route, I have a pair of boot clamp pliers I'd be happy to loan you.
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Dec 2008
    Woodland Hills, CA
    I just went thru this as well. I found water in the right outer CV joint and it had been there long enough to corrode. The inner was good, but I hadn't even looked at the left side. I opted to just replace both sides. It was actually cheaper to just buy new assemblies...and no greasey labor.
    Apr 2011
    This is a very good, detailed thread about CV joints/axels and their repair also see More CV Repairs and hardware
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Feb 2010
    San Francisco, CA
    small update
    All this talk of CVs got me investigating my own. As it turns out, the newer complete axles that come with the 2 pin +4 bolt config have a slightly different tin holding down the boot. The newer tin seems like it's a standard 6-bolt type (with 6 holes). This means that there are holes over the roll pins that can lead to grease leaking out and getting flung all over the underside of your car. In comparison, the older style "tin" pieces have only 4 holes and the roll pin areas are covered, making a better sealed unit.
    From my limited research, it seems like the older style tins no longer come on the new complete axles.
    The solution would be to either seal up the extra holes somehow, or to reuse your old tins. I'm wondering how others have fixed the issue of grease coming out of the holes?
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    Apr 2011
    To illustrate your point
    Name:  Screen Shot 2013-04-10 at 10.50.10 AM.jpg
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Senior Member CidTito's Avatar
    Jan 2008
    Emeryville, California
    I rebuilt mine last year, and lucky for me, I found no corrosion. After a rather short decision to rebuild rather than buy new, I did forge ahead and did it. Parts were south of $40.00 for the pair. It took me most of one afternoon start to finish to do it making the hardest part for me, getting them out, and then putting them back in, but it wasn't "that" bad. Also, crimping those brackets back on was a bit frustrating. The greasy part wasn't bad at all. I have to say, you can make it a lot less messy if you don't use any of that grease they provide until the very last possible minute.
    Tip:
    1. Take your used blue surgical rubber glove and carefully stretch to encapsulate your rebuilding work while in other areas.
    2. Carefully spend a little while wiping down the underside of your engine, transmission and other areas before starting. Its gonna to be a lot more pleasant as you reassemble.
    E911SR #2107
    69 911T/S SWT 3.2L
    RG #384
    Jun 2011
    Mound, Louisiana
    Mine at 105K, new boots-grease, balls, etc look great. So is it really bad, or is the boot just broken? Seems kind of rare to be worn out or broken, unless the boot broke and all the grease escaped.
    Paul Harrop 12.5% German.
    Early S #2059
  1. CV joint recommendation for 67 911
    By 1QuickS in forum Technical Info
    Last Post: 03-23-2014, 06:23 PM
  2. CV joint grease
    By Merv in forum Australia
    Last Post: 12-21-2013, 11:48 AM
  3. SWB CV joint
    By Christophe Penard in forum Technical Info
    Last Post: 10-07-2013, 06:02 AM
  4. CV joint boot ???
    By Davz912/911 in forum Technical Info
    Last Post: 03-25-2008, 01:22 PM
  5. Why different CV joint sizes?
    By caproader in forum Technical Info
    Last Post: 08-20-2006, 03:43 PM
