Results 1 to 8 of 8
Thread: Luggage compartment lights
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    Hi, gang:
    The front luggage compartment lights haven't worked on my 1969 911S since I bought the car some years ago. Today I tried to rectify the problem, so I checked the bulbs and fuses...all were okay. Next I followed the wiring in the front hood and I found that the main (white & black) power-supply line that runs down along the right side hinge wasn't connected to anything in the trunk...obviously the source of my problem.
    Here are what I hope to be some easy questions for you:
    1) When do the luggage compartment lights work? Only with the headlights on? Always?
    2) Is there a switch that turns them on when the lid is raised?
    3) Where does the main (white/black) power line connect to after it runs down along the right hinge?
    Thanks in advance for your help!
    Lopena
    New Jersey
    Feb 2011
    Spain
    They work only when headlights are on, the switch I believe is in the driver side hinge and it works when the trunk is opened or closed. I believe the wiring goes to the switch.
    Here is an older thread that explains it:
    http://www.early911sregistry.org/for...k+light+wiring
    Early 911S Registry #2590
    Senior Member CidTito's Avatar
    Jan 2008
    Emeryville, California
    Quote Originally Posted by frankmar View Post
    I agree, works like the refrigerator when its ON.
    E911SR #2107
    69 911T/S SWT 3.2L
    RG #384
    Dec 2011
    Victorville CA
    The switch is on the passenger side hinge.
    Dec 2010
    Southold, NY
    I'll have to look, but I seem to remember that the trunk light circut is active only while the parking lights are on and not with the headlights. Please check my memory.
    Not sure if the '69 trunk light circuit is different than my '73... but the '73's light actuation has nothing to do with the key, or front light circuit at all. You open the hood and the light comes on, with the keys in your pocket and the front lights off.
    Chuck
    Feb 2011
    Spain
    Mine is a 69s European version and work only when headlights on...
    Luft gekuhlt Bummler's Avatar
    May 2005
    The Valley...
    Trunk lights on my '69 E US delivery come on when the headlamp switch is pulled out to either the first detent (parking), or all the way (headlamps).
    Stefan Josef Koch
    RGruppe #194/SRegistry #1063
    2015 Porsche Cayman S
  1. Luggage compartment light wiring help
    By classic in forum Technical Info
    Last Post: 12-11-2015, 03:02 PM
  2. Replies: 3
    Last Post: 05-15-2013, 07:26 AM
  3. WTT: Lining for Luggage Compartment
    By CidTito in forum Free, Trades, and Swaps
    Last Post: 02-27-2013, 08:24 PM
  4. Luggage compartment SWB - satin black question
    By IAA1963 in forum Technical Info
    Last Post: 08-15-2011, 07:02 AM
  5. Wanted: Luggage boot trim/lining for luggage compartment
    By vricardo in forum For Sale: 911 Parts
    Last Post: 02-02-2007, 09:18 PM
