Results 1 to 10 of 12
Thread: LSD 901 oil
    Feb 2011
    Spain
    LSD 901 oil
    Hello! I have an LSD transmission in my car, it gets regular street used about 3000 miles a year. What would be the recommended oil and interval change?
    Early 911S Registry #2590
    Feb 2011
    Spain
    I see that most people recommend Swepco 201
    Paid Member # 1991
    Apr 2010
    Seattle, WA
    Quote Originally Posted by frankmar View Post
    I like Swepco 201 (blue) in my 901-type transaxles. Just replaced in the -E this past weekend, as a matter of fact. I thought the LSD required something "special" however. I'd check on that before I put Swepco 201 in a LSD transaxle. Open to corrections/clarification from others.
    - MR
    I have never liked Swepco, tried it once in a 901 with an LSD and found it didn't have a positive impact on the gearchange.
    I have used Redline 75W90NS ever since and would add the miniumum amount of 'friction modifier' needed to stop any chatter of the LSD plates.
    Dec 2007
    NYC
    Amsoil has a limited slip additive in their trans oil. I do use it and it did stop my LSD chatter. They also make a seperate LSD additive if you want to use something else.
    1970 911S
    1963 Abarth Monomille
    1974 2002 Turbo
    Feb 2010
    San Francisco, CA
    I run Swepco in my LSD 915 w/o any additional friction modifiers. This is also the recommendation of my mechanic.
    That said, many others like Redline + modifier as Chris said.
    Not sure how much of a difference there is for the oil requirement on a 901.
    E911SR & RGRUPPE
    '73 S Coupe #306
    Feb 2003
    Corpus Christi, Texas
    Swepco 201 has friction modifier for use with a clutch type LSD. If you want synthetic, Red Line 75W90 has friction modifier whereas the 75W90NS does not.
    Jason Burkett
    Paragon Products
    www.paragon-products.com
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1972 911T
    1974 914 Limited Ed. Blk/Yellow
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    1968 Shelby GT500 Conv.
    2010 VW GTI, Daily Driver
    Senior Member 68S_SK2's Avatar
    Mar 2006
    Munich, Germany
    Hello,
    In 2006 have verified that topic at the Porsche Classic Department:
    If you install the ZF LSD 904 type for your 901 gearbox you should either use Shell Spirax A 90 LS or Shell Spirax MB 90 gear oil. These are the only 2 types which are allowed for the early 904 LSD.
    Claudius
    Feb 2011
    Spain
    Hello! Any real experience with the Shell Spirax lubricant?
    Mar 2006
    Munich, Germany
    I use the Shell Spirax A 90 LS for my 901/02 gearbox with 904 LSD and it works perfect. Now this type is replaced by Shell Spirax ALS 80W-90 as far as I know.
    Claudius
