Results 1 to 9 of 9
Thread: Front wheel bearing seal removal tricks
    Nov 2011
    US
    I have the front hubs off to do a wheel bearing repack but I am struggling with getting the old seals out of the hubs. I would usually just pry them out with a large screw driver but this isn't getting it done. Does anybody have some tricks for removing these without marring the hub badly?
    Jul 2006
    Corvallis, OR
    Don't use a screw driver! You need a large brass punch. You can buy these at places like Sears or tool shops etc. The large brass punch will grab the sleeve and not hurt the hub. Find the largest one you can and use it on a solid surface with a hammer. Go in a star pattern as use hammer it out.
    72S, 72T now ST
    If you're going to replace the wheel bearings then just hammer against the bearing (with a punch) and it will push out the seal.
    -Marco
    TLG Auto: Website
    Jul 2006
    Corvallis, OR
    This is what they look like. Get a solid surface like your garage floor. Wear gloves and goggles and hammer away in a circle spinning the brass punch to get a good grip. They will pop right out. -Scott
    72S, 72T now ST
    anybody have the dia. for that punch?
    Or you could buy a seal removal tool from any of the large tool suppliers.
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    Quote Originally Posted by 37yrold911 View Post
    Never seen one like that.. I use one of this type, and yes the pointy ends can be hazardous to your fingers.
    http://www.amazon.com/Lisle-56750-Se.../dp/B0002SRCKG
    Mark..
    That's the one,,,
  1. First Engine Removal, Tips/Tricks/Questions?
    By Stretch32 in forum Technical Info
    Last Post: 02-03-2013, 12:54 PM
  2. Front inner wheel bearing removal
    By Bob Harriman in forum Technical Info
    Last Post: 09-03-2012, 08:24 AM
  3. front wheel bearing service interval
    By 356robo in forum Technical Info
    Last Post: 10-08-2010, 05:04 PM
  4. FS: Rear wheel bearing removal puller
    By a911s in forum For Sale: 911 Parts
    Last Post: 01-03-2010, 06:41 PM
  5. Fan removal tricks?
    By wit61 in forum Technical Info
    Last Post: 02-21-2003, 07:06 PM
