Thread: SWB door question
    SWB door question
    Does the lever for the inside door handle point up or down. I don't have my handles nearby to test fitment. Haynes has them pointing up...I just need to confirm. Anybody have the door panels off that can help me confirm?
    Thanks.
    Speedo
    registry# 1283
    What lever? SWB doors use a button.
    The lever the button in the armrest actuates. The bracket that hold the lever (bellcrank) has 4 bolts that hold it to the inside of the door chassis. Does the lever mount pointing up or down. I have done a photo search and found them pointing both ways.
    registry# 1283
    Dec 2008
    Black Mountain, NC
    Lever with the ball crank gos UP, note the attachment is 2 short head allen screws, and 2 odd special fasteners that I think the arm bolts to they are on opposite corners. Just checked on a spare door in the garage attic, let me know if you need a pic.
    Yes, we were posting at same time
    I concur, the ball is above the pivot, in other words, it points up.
  1. Question About SWB Door Skins
    By mshaver51 in forum Technical Info
    Last Post: 01-07-2012, 07:18 PM
  2. Door pocket question
    By EA911 in forum Technical Info
    Last Post: 04-14-2009, 02:21 PM
  3. Door top seal question
    By NTW in forum Technical Info
    Last Post: 09-17-2008, 11:56 AM
  4. Door Pocket question
    By joetiii in forum Technical Info
    Last Post: 02-08-2007, 06:18 PM
  5. Here's a Door Question
    By larry47us in forum General Info
    Last Post: 09-28-2004, 04:03 PM
