Thread: Need help on Headlight wiring issues 72T
    Dec 2012
    Concord NC
    Having some wiring issues with my new car and am clueless on German wiring. Found some wiring diagrams and suspect it may be a relay or switch issue. Wanting some fatherly advise before barking up the wrong tree.
    Photos show lights on low and high beam with driver side looking like its not grounded. Pulled the headlight bulbs and switched sides. They check out ok. Fuses look ok and meter show its grounded. Headlight were working fine up until a few days ago. Any ideas?
    1972 911T
    1934 Ford Pickup
    1955 Ford pickup
    !955 Chevy Sedan Gasser
    1986 Ford Pickup
    1931 Ford Model A Roadster
    2000 Suzuki GSXR1000
    1976 Harley Davidson Shovelhead bobber
    Use your volt meter and see if you have equal voltage to both sides. If not go right to the fuse box and see if you have equal voltage directly from the fuse terminals.
    Aug 2011
    New York
    It is possible that even though the meter shows ground, that the ground connection is insufficient for the amperage the lamp draws. It wouldn't hurt to clean the ground connection at the chassis.
    E Sully
    1973.5 911T
    Dec 2012
    Concord NC
    Where do the headlights connect to ground on the harness? At the fuse panel on the driver's side?
    1972 911T
    1934 Ford Pickup
    1955 Ford pickup
    1986 Ford Pickup
    Jan 2006
    Naperville, IL
    They ground to a stud on the outside of the battery box (one on each side).
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Dec 2012
    Concord NC
    That is where I found the problem. There was no grounding wire to driver's side stud so I ran a single brown wire from the plug to that grounding stud and that solved the issue. Thanks for the help!
    1972 911T
    1934 Ford Pickup
    1955 Ford pickup
    1986 Ford Pickup
  1. Headlight bucket wiring grommets ('67)
    Last Post: 03-31-2014, 05:56 PM
  2. Headlight wiring routing question ('67)
    Last Post: 11-21-2013, 11:16 AM
  3. Connector for headlight wiring harness
    By DJ911 in forum Technical Info
    Last Post: 08-13-2012, 05:38 AM
  4. Headlight Wiring Harness Help
    By t6dpilot in forum Technical Info
    Last Post: 10-02-2010, 06:11 AM
  5. 1966 Headlight bucket wiring
    By red911 in forum Technical Info
    Last Post: 09-12-2005, 06:55 PM
Tags for this Thread
