Results 1 to 10 of 11
Thread: Steering wheel nut removal
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    Clockwise (reverse thread) or counterclockwise to remove the steering wheel nut? Thanks
    Jul 2008
    South Florida
    Lefty loosey, righty tighty.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    When I remove the nut at the steering wheel I find it helpful to unbuckle my seat belt first.
    Apr 2011
    N.Calif., south of SF
    27mm nut. Don't use the steering wheel anti-theft lock mechanism to hold the steering wheel.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Sep 2012
    Toronto
    Thanks Haasman for that cautionary advice. I read on another thread that you can turn the wheel fully counterclockwise and then remove the nut. Is that an advisable procedure?
    Apr 2011
    I wouldn't. Simply hold the steering wheel in place, possibly have an additional person help you. I wouldn't want to put stress on the pinion gear and steering rack assembly. Since the stock steering wheels are fairly large in diameter, they provide good leverage. If the nut is stuck, trying tightening very slightly, then removing the nut in a counter-clockwise direction.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Senior Member 767driver's Avatar
    Oct 2008
    Parkton, MD
    I just swapped my steering wheel the other day. Easily done by yourself...just hold the wheel and use a breaker bar...it should come loose without too much of a fight.
    Lee Fishpaw
    O Gruppe #20
    Early S Reg #2175
    R Gruppe #714
    '70 914-6
    '88 911
    '85 928S
    '74 260Z
    '74 TR6
    Quote Originally Posted by Haasman View Post
    I find that with any nut difficult to remove, tapping it using a drift and hammer helps to break the thread bond.
    John Schiavone
    Connecticut
    Sep 2012
    Toronto
    Thanks for your various replies. Here's the technique I used that was suggested on another thread. After applying WD40 and letting it sit over night I used the "Club" steering wheel lock device to counteract the force of the breaker bar. Worked great. Was surprised that no wheel puller was required to separate the wheel from the steering column.
    Here's the new Nardi wood wheel installed:
    Quote Originally Posted by BrentF View Post
    That's the German precision you pay for, any country that can build guided missiles in the forties isn't going to hammer on steering wheels
  1. Steering wheel removal
    By luke-44 in forum Technical Info
    Last Post: 04-07-2013, 04:36 PM
  2. Steering wheel removal??
    By Zuffenhausen in forum Technical Info
    Last Post: 11-27-2009, 12:15 PM
  3. steering wheel removal?
    By 300814 in forum Technical Info
    Last Post: 11-01-2009, 10:40 AM
  4. Steering Wheel Removal
    By roray in forum General Info
    Last Post: 05-09-2009, 02:52 PM
  5. 73.5 steering wheel removal....help!!!
    By KJensen in forum Technical Info
    Last Post: 10-26-2005, 01:00 PM
