Keep it simple.
Keep it simple.
Mark Jung
MFI Werks
Early 911S Registry #972
Carrera T w/LWB, MT, RWS, PCCB
72 T 66 x 100 MFI Twin Plug Coupe
R Gruppe #686
How much different does the car sound on acceleration vs the original air cleaner box?
There is clear difference in the sound of my 1972 911T MFI when I take my air cleaner box off. The sound without the stock air box on is magnificently more intoxicating.
You can hear the intake trumpets!
I would like to achieve that sound safely and these look like the way to do it.
1969 911T Coupe Blood Orange (Vivy)
Perry,
It's pretty loud but, to be honest, the intake noise is drowned out by the Liestritz 2-out sport muffler I'm running.....
Either way, I know its louder than a stock air box and it sounds great in my opinion.
Stretch
Registry # 3063
any of these air box replacements for MFI clear a decklid that has an AC condenser? I'm finally getting blucille back together and the A/C bits hit the gorgeous fiberglass air boxes I bought from Ed.
Since Porsche is somewhat famous for their airbox designs... doesn't this impact torque and drivability? At the very least I'd expect that you'd need to re-calibrate the MFI pump.
1970 2.2S Elfenbeinweiss
2002 996 TT Midnight Blue
Member #3833
It’s possible there might be some impact but the only way to know would be a dyno comparison I guess (or seat of the pants feel?). How big is the difference between a stock air box and a more open induction system with regard to power / torque? I will say the car has pretty good torque and drivability in its current setup so I’m not sure how much noticeable difference there would be switching to a stock air box.
The MFI pump was set up with a modified space cam to work with the DC40 camshafts and the engine displacement / compression ratio so that shouldn’t be an issue. I still need to hook up my temporary AFR gauge and check / adjust the MFI fuel flows to see if any are needed.
Stretch
Registry # 3063
