Results 1 to 10 of 15
Thread: Looking some informations about oil filter plate 911R 908 906...
    Ready for the Hunaudières manu72S's Avatar
    Nov 2004
    hello
    I am looking for informations ( type, thread dimensions,...) about the oil filter plate for 911R or prototype.
    I didn't find any one to restore just for our knowledge.
    Thanks in advance
    Best from Le Mans
    Manu
    Jan 2011
    Sunny Southern France
    I'm happy to have the oppurtunity to help someone in this forum once!
    These oil filters are somehow a real mess!
    Actually, there are at least 2 different types. They are all strainer filters, that means that the filtering elements are made of metallic mesh discs.
    The differences are in the number of discs, and then their size.
    356 Carrera and maybe 550 spyders: Small bowl
    904: Same as 356
    911R: Same as 904
    906: "big" bowl
    you'll probaby find 906's fitted with 904 ones and 356 may have seen even smaller bowls.
    The top plate is the same for all If I'm not wrong.
    Threads as M26*1.5 from memory
    For the little story I managed to find 5 NOS units last year. They are very hard to find... They were used on some helicopters, as a gearbox oil filter back in the day... Be prepared to pay more than 1000$ if you really want one!
    I have some pictures, and will try to dig'em out this WE if you want.
    Olivier.
    For what it is worth, I have found the ones used on 356's to be dated.
    Manu,
    Here is a picture of a 906 "big bowl" type. The R used the same big bowl. Note the unit found on the R had a bolt that extended all the way through the base of the bowl, secured with an acorn nut at the top. The bolt possibly aluminum. The acorn nut looks to be the same used on 911 engine case bolts. The port inlet and outlet on my console are m22x1.5.
    Take care,
    Brad Davis
    Brad Davis
    RGruppe #691
    Early 911S #1547
    900.027.015.01 Spring ring washer, B 8 DIN 127 phr SS 90002701502 Qty: 2
    900.076.013.02 Hexagon nut, M8 DIN 934-6S verz Qty: 2
    900.136.013.02 Threaded socket (adapter), A 16 DIN 7627-St verz. Qty: 2
    900.123.011.39 Seal ring, A 22x27 DIN 7603-Al Qty: 2
    999 070 004 02 Cap nut, Qty: 1
    901.107.268.00 Screw for oil filter Qty: 1
    While on the topic of this filter console ... Thanks to the help of a few friends I made a handful of the brackets this console mounts to. The bracket is employed in the R and select few T/R. The brackets are accurate in all dimensions even the spot weld pattern. I you need one for you project or restoration I am happy to help.
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Jan 2011
    Jimmy and Brad, great pieces!
    Jimmy do you plan to repop some?
    here are some pictures of the small bowls:
    I made & sold 10 for prototype restorations back in the early 80's. The rendering was just for clarity.
    May 2005
    Oroville, CA
    Ben Coles has some reproduction filters on his site. Don't know hold old the info is or the quality but they sure look good in the photos.
    H
    Quote Originally Posted by Harvey Weidman View Post
    H
    His website it up to date. Had a correspondence with him not too long ago.
    -Marco
    TLG Auto: Website
  1. FS: 911R, 904/906 style oil filter
    By 718RSK in forum For Sale: 911 Parts
    Last Post: 08-26-2014, 06:32 AM
  2. Replies: 3
    Last Post: 02-03-2014, 08:55 AM
  3. FS- Used 906/911R Flywheel & Pressure Plate
    By 72tii in forum For Sale: 911 Parts
    Last Post: 11-01-2009, 03:55 PM
  4. WTB: Rubber Grommets for MFI Fuel Filter Mounting Plate
    By RTincher in forum For Sale: 911 Parts
    Last Post: 10-01-2006, 09:03 AM
