Page 1 of 8 123 ... LastLast
Results 1 to 10 of 75
Thread: Best tire size for 66 SWB w 7x15's?
    Atlanta, GA
    Before you say they won't fit, let me clarify that I have flared fenders on the car. Car has 205/60 15's now. Is that a good size or do I want to consider other options? Also, what are some recommended brands for this size. I am going for the sports purpose look. Thanks
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Dec 2008
    Woodland Hills, CA
    I'm running 205/60/15s on my SWB... 7x15 Steelies...Stock fender flares.
    I am using 185/70 Vredestein Sprint classics on 15x6 now-- they are a good compromise between light weight and tread width. SWB cars in particular have a heavy suspension, so minimizing unsprung weight is a good idea, and unless you are racing, the extra rubber is overkill. I would go as light and as narrow as possible for street use, maybe use a spacer in the rear to put the wheel in the flare better.
    Atlanta, GA
    185/70 on a 7x15? I did not think you could run this skinny of a tire on a 7" wide wheel? Thanks
    Mark Erbesfield
    1957 356A #58648
    Dec 2010
    Tulsa
    Check out 205/50, 205/55, or to really get down - 225/45. These tires will put the car on the ground (23" tall) for better handling, and have 7.5 to 8.5 tread width. These are for sporty street/autocross purposes on 7's, and they're no heavier than 195's or your typical 205/60.
    Dec 2008
    Woodland Hills, CA
    Can you elaborate on the "SWB cars...have a heavy suspension" comment? I can tell you that my Steelies are very heavy compared to my Fuchs with 195s.
    Atlanta, GA
    Does anyone have any pics of car w shorter tires than the 60 series, like the 205/55 mentioned? I like the idea of the car being lower but worry about not filling the fenders and having it look funny. I am also concerned about the speedo error. Not sure how off the 205/60's are but the 205/55 drops even more.
    Mark Erbesfield
    1957 356A #58648
    Quote Originally Posted by gsjohnson View Post
    The control arms that have to transmit the springing forces in bending are heavy, the bolt-together strut is heavy, the rear suspension is well...
    Quote Originally Posted by merbesfield View Post
    Back in the 1977 friend of mine bought a 74 911 with 185/70/15's on 7in all around. It looked pretty "cool" as remember. I would like to see a picture to refresh my memory.
    Aug 2005
    Bucks Co., PA, USA
    Quote Originally Posted by bliebler View Post
    I run 195/65/15 on 7s all around, but mine is a LWB so may not be pertinent. Apologies if so. Left rear rubs rarely, right rear never rubs.
    Last edited by teenchy; 05-11-2013 at 04:40 PM. Reason: added photo, elaborated on fit
    ESR #1474
  1. tire size rsr 73
    By gwilliams in forum Technical Info
    Last Post: 12-08-2011, 06:01 PM
  2. Best tire size for a 73 with 7s ??
    By Rennman in forum Technical Info
    Last Post: 07-13-2011, 10:25 AM
  3. autoX tire size
    By joetiii in forum Technical Info
    Last Post: 05-20-2009, 07:32 AM
  4. 67S tire and size
    By mwilson3003 in forum Technical Info
    Last Post: 09-03-2007, 09:42 AM
  5. tire size question
    By RC70SCoupe in forum Technical Info
    Last Post: 03-19-2007, 08:54 AM
