Results 1 to 2 of 2
Thread: 98 fuel change to 95
    Feb 2011
    Spain
    I've been running 98 octane fuel in my 69s MFI and now changed to 95 octane. I think I see idle go down by ablu 100 rpm and maybe a bit of a loss of power. Is this just psicological or real? do I have to change the air or fuel mixture?
    Early 911S Registry #2590
    If it is only gasoline in both cases it is just your imagination and no mechanical changes are necessary. If the lower octane has more alcohol in it than the higher octane, then the effect could be real and you might want to slightly tweak the mixture.
  1. Help, Can I change my user name?
    By Bernie B in forum Test Area/Help
    Last Post: 03-28-2012, 04:19 AM
  2. when to change shocks
    Last Post: 02-04-2011, 07:24 AM
  3. Want a change
    By boxster03 in forum General Info
    Last Post: 10-04-2007, 09:23 AM
  4. Oil change now or in the Spring?
    By gruen911 in forum General Info
    Last Post: 11-25-2005, 07:53 AM
  5. Some things never change -- '72 vs. '66
    By RandyWebb in forum General Info
    Last Post: 01-26-2004, 04:37 AM
