Results 1 to 7 of 7
Thread: Need help with engine number
    Jun 2012
    San Jose, Ca
    Trying to figure out what motor has the number 969006. Can anyone help, please?
    Nathan
    Restoration newbie.
    Jun 2007
    San Francisco
    Photos of the serial number and type/production numbers would help. As well as pics of the engine itself.
    96XXXX is a 67S engine but the first X would only have the values 0, 1, or 2.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Jun 2012
    San Jose, Ca
    Thanks Andy. Will take a closer look to confirm the number and post some pics when I get them. Also, where would I find the type/production numbers on the motor?
    Nathan
    Restoration newbie.
    Jun 2007
    San Francisco
    Looking into the fan they are on the right side. The serial number should be upright on the "seat" for the fan housing. The type and production numbers are to the right again, above the right chain box.
    Here's a picture Grady posted on Pelican:
    Green is where your engine number should be. Red is where your type and production number ought to be. The case in the picture was a factory replacement hence no stampings I believe. (Ignore the yellow arrows)
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Jun 2012
    San Jose, Ca
    Perfect, thanks Andy. I will take a closer look.
    Nathan
    Aug 2009
    SF Bay Area
    Quote Originally Posted by ajwans View Post
    andy
    If it were a 67S engine, the engine number would be facing the rear, in plain view, not facing to the right like all mag case engines.
    Jim
    Oct 2008
    Burford, ON, Canada
    This thread has all you need to know about the numbers to look for on the engine:
    http://www.early911sregistry.org/for...Engine-Build-s
    Add your info to this thread.
  1. No engine number??
    By ccporsche in forum Other Porsche Passions
    Last Post: 06-03-2013, 06:26 AM
  2. looking for 72S engine number ?
    By manu72S in forum General Info
    Last Post: 04-09-2009, 09:36 AM
  3. 2.4S Engine number
    By CHK in forum Technical Info
    Last Post: 12-09-2007, 01:17 PM
  4. Engine Number
    By mwilson3003 in forum Technical Info
    Last Post: 08-03-2007, 01:29 PM
  5. Engine Number help
    By Vintage911racer in forum Technical Info
    Last Post: 11-15-2003, 07:39 AM
