Thread: Need help sourcing a fuel line
    Senior Member BlackC4's Avatar
    Apr 2011
    Atlanta, GA
    Guys I need help finding a part. It's one of the fuel lines with the banjo bolt and fitting. I can't seem to find these complete only kits to build your own. I've checked the usual parts suppliers but have not yet called PCNA. Does someone sell these assembled or am I going to have to have these made?
    Thanks!
    '73.5 911T Coupe Sportomatic Light Yellow (117)
    '73 911T Targa Sportomatic Light Yellow (117) - Sold
    '99 996 Carrera 4 Black - Sold
    The Other Stuff:
    '63 Corvette Split Window
    '67 Datsun 1600
    '88 BMW M3
    '96 BMW M3
    '88 BMW M5
    Feb 2012
    Edmonton
    Do you need the one that goes to the injectors?
    I think they're still available from Porsche, part number 911.110.093.00
    Apr 2011
    Atlanta, GA
    I think that's the one. Thanks!
    The Other Stuff:
    '67 Datsun 1600
    '88 BMW M3
    '96 BMW M3
    '88 BMW M5
    Aug 2011
    New York
    I have purchased those CIS lines from the local Porsche dealer a few years ago. More recently I have bought different size lines from Unobtainium and used the original fittings to replace lines. He has the correct wall thickness lines and they are fairly easy to faricate.
    E Sully
    1973.5 911T
    Apr 2004
    35,000 ft
    It looks like the one on the fuel distributor at almost 12 o'clock in the photo has already been repaired. You can find/get/source a new end and just gently warm up the black fuel line, insert the replacement end into the warm line and you will be good to go.
    These same lines were used on a huge variety of (mostly European) cars from the mid 70's into the 80's so they are pretty common on BMWs, volvos, SAABS, audis, etc. if you've got a local independent European repair shop, I'm sure they can help you out.
  1. leaking fuel line
    By ferry58 in forum Technical Info
    Last Post: 02-19-2013, 06:30 PM
  2. PMO fuel pressure control unit - return fuel line?
    By lkadams in forum Technical Info
    Last Post: 05-27-2012, 05:58 PM
  3. WTB MFI fuel line banjo
    By budge96 in forum For Sale: 911 Parts
    Last Post: 03-26-2011, 10:43 AM
  4. Fuel line replacment
    By cmcfaul in forum Technical Info
    Last Post: 05-01-2010, 12:31 PM
  5. Fuel Line
    By kissov356 in forum Technical Info
    Last Post: 06-26-2006, 12:45 PM
