Thread: Brake caliper lube
    Nov 2011
    US
    Brake caliper lube
    What products are recommended for lubricating seals and boots etc when rebuilding calipers?
    I asked Eric but did not write it down... I hope he sees this post.
    ATE Plastilube
    Dec 2008
    Black Mountain, NC
    NAPA has a product Sil-Glyde that I have used for many yrs when I could not find the ATE, easy to find.
    I like the ATE Assembly Paste. Not sold in the US, but you can hunt it down and order is from overseas. Here is a group in the UK, http://www.coolairvw.co.uk/Item/Shop...CB-_180Gr.html
    Sil-Glyde is great stuff too.
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Jan 2007
    North of the GG Bridge
    Here is some info I have been collecting regarding paste / lube:
    Assembly lube, grease, paste:
    * ATE brake paste - impossible to get in the U.S.
    * AGS Sil-Glyde - available at NAPA or other better auto parts stores
    for about $7 a tube. If you don't want to buy a tube, Autozone has
    little packets.
    * Dow Corning 111 - available at Grainger; $8.50 per tube.
    (Dow Corning 4, 4X, 111, and 112 are all suitable for use in rebuilding calipers)
    * Lucas/Girling red rubber grease - available from Brit parts houses
    * Motorcraft Silicone Brake Grease
    * Permatex Ultra Brake Lube - supposed to be safe for internal use,
    but the MSDS shows it's 90-95% "synthetic oil" so I don't know if
    it's truly rubber safe.
    The DC 111 grease is good for up to 400F, Sil-Glyde 600F.
    Here is the "Kind"; ask a Euro member to send you some:
    Nov 2002
    San Dimas, CA
    Ate Plastilube's available from Sierra Madre Collection in 35 ml and 75 ml tubes. It's what the instructions that come with the Ate seals say to use.
    There are probably other sources.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  1. Brake Caliper Locked up
    By red911 in forum Technical Info
    Last Post: 09-08-2012, 06:22 AM
  2. Brake Caliper Color
    By JimVillers in forum Technical Info
    Last Post: 08-12-2012, 02:16 AM
  3. alloy brake caliper
    By our911s in forum Technical Info
    Last Post: 07-05-2010, 06:58 PM
  4. Brake caliper bolts SWB
    By tlmsf in forum Technical Info
    Last Post: 03-28-2010, 02:05 PM
  5. rear brake caliper
    By Francois Duval in forum Technical Info
    Last Post: 11-30-2009, 05:26 PM
