Thread: Installing oil cooler system - use rivet nuts or welded in threaded studs?
    Feb 2012
    Sweden
    Hi
    I am in the process of restoring a -70T and will install dual oil coolers. The car is currently bare metal and before it goes to paint I want to decide how to mount the oil coolers and pipes. The later 911s use threaded studs which are welded to the rocker panel. Elephant Racing's after market kits use rivet nuts to hold the brackets for the coolers.
    What would you recommend I use - rivet nuts or welded in threaded studs/brackets? Pros / cons?
    Thanks in advance!
    /Johan
    Feb 2012
    Sweden
    Quote Originally Posted by sten View Post
    Now, ITS TIME FOR YOU TO UPLOAD PICTURES!!!
    I will go see it once all the bodywork is done, right before it goes to paint. This should hopefully be in 2-4 weeks. After that I can promise you some pictures
    Here's how I did mine, a 6 X 1.00 weld nut, and install with a plastic spacer so you don't deform the pipe bracket.
  1. FS: Head Studs and head Nuts
    By cmcfaul in forum For Sale: 911 Parts
    Last Post: 04-26-2014, 06:48 PM
  2. FS: Oil Cooler from 70 911S 2.2 - threaded
    By Unobtanium-inc in forum For Sale: 911 Parts
    Last Post: 10-10-2013, 08:52 AM
  3. swb grill studs + nuts
    By ajwans in forum For Sale: 911 Parts
    Last Post: 07-09-2012, 06:49 PM
  4. Behr Oil Cooler Threaded
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 02-07-2011, 04:52 AM
