Results 1 to 8 of 8
Thread: Strange Engine Number
    Sunshine State
    I'm working on an engine that is supposed to be a 1970 2.2L. It has Zeniths. The engine number is 6022930. It doesn't seem to match any of my references. Any help appreciated.
    Oct 2008
    Burford, ON, Canada
    I don't know of any serial starting with 60. Give me a photo of the serial #, the engine type #, and the case casting part #'s (901.101.101 xR and 901.101.102 xR from the sides of the case under the oil return tubes.
    Jul 2003
    Santa Cruz, CA
    No type number?
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Sunshine State
    I can get pics tomorrow. 901 106101 5R
    Sunshine State
    Looks hand-stamped. But why this number?
    Jan 2003
    NW Indiana
    Hi Curt,
    Agreed, the font of those numbers are not factory correct and there are no stars on the ends of the number sequence. The '6' is a give away. Guess that explains it somewhat. At least it is not a duplicate of an original serial number. Is there a type number in the usual location?
    Brian
    '71T
    R Gruppe #299
    Sunshine State
    Edit: looks like 911/07 which is consistent with what it is supposed to be.
    Oct 2008
    Burford, ON, Canada
    The 2.2R casting revision is 1970 or very early 1971, however the serial is missing the stars, and the stamping area looks a little strange. If there is a type #, then I would think it was a shaved and stamped serial, if not then a new unstamped case was used. If no type #, then I would shave off the serial you have there, and leave it blank.
  1. Strange COA for 1965 built 911 regarding engine number
    By srogebry in forum General Info
    Last Post: 11-30-2018, 03:20 AM
  2. Engine number help!
    By schnell in forum General Info
    Last Post: 08-01-2013, 03:39 PM
  3. Strange VIN / Engine Number combination
    By wolfgangg in forum General Info
    Last Post: 01-03-2010, 10:52 AM
  4. 69S with strange smoking engine problem - help.
    By rngpc in forum Technical Info
    Last Post: 11-09-2005, 07:04 PM
  5. Engine number ID
    By nullh20 in forum General Info
    Last Post: 07-21-2005, 08:09 PM
