Thread: Remove wiring harness - 67 firewall plugs
    Nov 2010
    Harleysville, PA
    Last step before body resto is to remove the wiring harness on my 67.
    There are 3 rectangular plugs that are mounted in the firewall to transfer all the signals and power between the dash instruments and switches and the main harness in the front trunk. How are these removed?
    I want to be careful because I don't want to damage them since I am sure they are hard to come by. Is there a way to pull the plugs out without damaging them? I have heard that the 67 plugs are unique in some way.
    Thanks for you advice!
    Mark
    1967 911S - 306465
    1980 911SC
    2005 Carrera Cabriolet
    Oct 2010
    Stockholm/Sweden
    They have small metal clamps (Barb´s might be the correct term) that hold them in place, I use a small screw driver to push them in while wiggeling them out.
    Porsche 935 DP1 Zirkelbach
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
    Feb 2011
    Surrey, UK
    As said above they have little tabs on the sides that you can just about see in this photo, and a recess. If you press the tabs with a small screwdriver and wiggle the plug they will eventually come loose. Required a whole lot more force than I was comfortable with, but no damage was done and they went back in ok. Try not to pull on the wires.
    Mick
    Nov 2010
    Harleysville, PA
    As they say, a picture is worth a thousand words. Seeing the socket removed I can see the retaining clamps. Hopefully with a small screwdriver or two, I can depress the clamps and wiggle them out (toward the trunk side I presume).
    Thank you for the help.
    Mark
    1967 911S - 306465
    1980 911SC
    Don't forget to label which is which and take about 50 digital pictures of both sides.
  1. How to remove the wiring harness on a 2.4 ?
    By lacouelle in forum Technical Info
    Last Post: 01-10-2014, 01:00 PM
  2. WTB: 69-73 911 Wiring Harness plugs for signal and wiper switches.
    By Martin Baker in forum For Sale: 911 Parts
    Last Post: 04-05-2013, 09:26 PM
  3. Wiring Harness
    By ret9191 in forum For Sale: 911 Parts
    Last Post: 02-17-2012, 04:47 PM
  4. WTB MFI wiring harness
    Last Post: 03-13-2009, 11:39 AM
  5. Wiring harness- how to remove completely?
    By drmrfi in forum Technical Info
    Last Post: 08-27-2008, 05:18 PM
