1968 911/912/911Lpre-delivery inspection sheet with instructions bulletin.
The sheet itself has a tear off that was supposed to be turned in to validate the warrranty, what I have are the instructions and the inspection sheet, blank. They are both in good condition for their age, but he instructions have a stain at the bottom and some tearing at the binder holes, the inspection sheet has a few creases, but they aren't hard ones.
Anyhow, with any luck you could bring this in with your car to the local dealer and say it was never inspected and can you please fix what's wrong with it. Probably not, but you might be the only person able to try. $350 delivered, I have one. The tearaway part is still attached, my scanner can't scan the whole thing so I cropped it, it is a legal or maybe a little bigger size piece of paper. My email is cs8815 at aol dot com.
Bulletin
Side one
Side two
