Results 21 to 30 of 34
Thread: Correct paint plate punch...
  1. #21
    Atlanta, GA
    Paint code plate
    Quote Originally Posted by Eminence Gris View Post
    Reviving ancient thread because as far as I know, nobody offers a decent stamping service. I need the alu VIN plate stamped on a customer car where the original was lost in a color change decades ago.
    There is a guy on IH8MUD.com forum that does Land Cruiser data plates. He does an amazing job. I bet he could do your paint plate. Try searching. If no luck let me know and I will try to find the info.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
  2. #22
    Dec 2003
    West Los Angeles
    Quote Originally Posted by merbesfield View Post
    That is excellent work. It is, however, engraving and not stamping. It would be good for later paint code plates.
    For anyone interested, here's the link: https://forum.ih8mud.com/threads/dat...rvice.1060963/
    techweenie.com
  3. #23
    Dec 2003
    West Los Angeles
    Well, further to this thread, I gave up and "restored" the ruined paint/VIN tag plate as best I could. Now my challenge is the alu VIN tag form the front of the car. On the subject car, it was lost in the color change and I have a proper blank for the year/model, but I do not have a stamping resource for this tag.
    Anyone?
    techweenie.com
  4. #24
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Got some very close stamps
  5. #25
    Dec 2003
    West Los Angeles
    That's great, Dirk. Would I be able to pay you to do the same for me?
    techweenie.com
  6. #26
    Apr 2016
    Stuttgart, Germany
    I ll send you the stamps.
  7. #27
    Dec 2003
    West Los Angeles
    That would be fantastic! Danke!
    techweenie.com
  8. #28
    May 2014
    South East USA
    Just adding to Dirk's kindness. I think Dirk's look good.
    I have these stamps in Santa Cruz.
    I've had them 20+ years and used them 3 times.
    My "3" is not flat on top.
    I could grind the "9" to look better.
    You can borrow if you wish.
    Scott
  9. #29
    Dec 2003
    West Los Angeles
    Thank you, Scott. As luck would have it, I do not need a "3."
    The tricky part, as I mentioned before, is that the stamps need different levels of pressure, depending on how much surface they are distorting, and I have a 1 and an 8 next to each other. So I may need a few beers before tackling it!
    techweenie.com
  10. #30
    May 2014
    South East USA
    They seem to make the same depth. If you keep a consistent hit.
    The real problem comes with the spacing. And a twisted number.
    I practice on a very similar thickness aluminum.
    You have to hit it on hardwood. And softwood. And on steel.
    Then choose the one you want.
    I draw the numbers out on tape.... So you can get the spacing right.
    The tape is right there. Next to it. You can even hit on top of the tape. Which might get real accurate.
    And you use that bottom ledge. With a touch of the stamp, to get them all the same height.
    I just did the brass plate by eye. So you could see them.
  1. Correct SWB paint details
    By Alan B in forum Technical Info
    Last Post: 10-31-2013, 09:42 AM
  2. Correct Karmann paint plate?
    By jesseandersson in forum General Info
    Last Post: 11-19-2012, 06:56 AM
  3. Paint tag and VIN plate removal?
    Last Post: 04-29-2008, 01:45 PM
  4. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
