Results 1 to 10 of 15
Thread: FS: Early 911S Koni Struts Date Code 48/72 and 28/73
    Have this nice set of 3.5 inch Koni struts. Part numbers 911.341.079.10 amd 911.341.080.10. They are clean and painted. Couple nicks from moving around but you will never know after a few miles. $700.00 OBO plus shipping (and sales tax in CA). Let me know if you have any questions.
    jonathan
    hwgunner
    gprparts
    800.321.5432
    Quote Originally Posted by hwgunner View Post
    This would work for 73 911 T ?
    Oct 2008
    Burford, ON, Canada
    Yes, but it is only part of the upgrade. You would require S calipers, vented rotors, and hubs for vented rotors. If you already have vented rotors, then you are in good shape. You also need the spindle nut since the Koni has a fine thread; hopefully this would be included. Also required are the Koni strut inserts for these particular struts.
    Thank you for the detailed reply !! I don't think I meet these requirements !
    Oct 2008
    Burford, ON, Canada
    They are a great upgrade, and you can use the A calipers which are less costly than the S calipers used in period. Jonathan could probably put together a package with all the parts necessary.
    Just curious, I have some S calipers somewhere, what else would be needed to install on a SWB or pre 69 chasis?
    Dan
    Quote Originally Posted by 1968DT View Post
    Dan
    You would need to get some 69 and later a-arms first. Then it is just a matter of building out the struts with the correct brake parts. Bearings, seals, rotors, hubs, caps and brake lines. I do have everything you would need if you would like me to put together a package. Let me know.
    jonathan
    hwgunner
    jonathan
    hwgunner
    gprparts
    800.321.5432
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Jonathan,
    Can you confirm that these take the wedge style ball joint, rather then the pinch?
    I'm uncertain of the year that they changed.
    TIA
    Tony
    Oct 2008
    Burford, ON, Canada
    I don't see a split in the lower end for the pinch bolt. I have a similar dated set of struts, and they are wedge bolt style. I think the change came earlier in 1972 during the 72 model year.
    Quote Originally Posted by classic View Post
    Jonathan,
    TIA
    Wedge Bolt, not pinch.
    jonathan
    hwgunner
    gprparts
    800.321.5432
  1. FS Koni Front Struts Date 4-73
    By gled49 in forum For Sale: 911 Parts
    Last Post: 02-07-2010, 12:31 PM
  2. FS - 1972 911S Pair of Koni Struts and 4 Shocks
    By K-squared in forum For Sale: 911 Parts
    Last Post: 06-11-2009, 05:02 AM
  3. FS - Early 911S Koni struts
    By jj83001 in forum For Sale: 911 Parts
    Last Post: 12-10-2008, 11:05 PM
