Thread: Webasto Pinch Bolt size?
    Does anyone know the precise dimensions of the bolt that pinches the Webasto fuel pump in place? I managed to lose mine.
    Thanks in advance
    Yes, do I win?
    M8 overall length 75 mm
    13 mm round head 6mm socket
    Shaft length of 70 mm
    W/ 25 mm of thread at 1.25 pitch
    Quote Originally Posted by SERIES900 View Post
    Yes, do I win?
    Yes, you are the winner!
    You win a test drive in the all-original car from which the above photo was sourced!
    (Don't forget to fill the tires! )
    Now about that muffler. . . how does the song go, "Ain't too proud to beg?"
    I forgot to give you the wiring harness for the late Webasto, will drop this in the mail shortly. Until then you will have to wear a sweater.
    Ahh that feels a whole lot better.
    Turns out I didn't lose it after all, it was hiding among some modern stainless bolts with the wrong headmark, hoping it would escape my notice.
  1. Bolt size for center rear license panel
    By merbesfield in forum Technical Info
    Last Post: 01-06-2014, 07:06 PM
  2. FS: NOS early cars pinch-weld
    Last Post: 09-22-2013, 04:43 PM
  3. Replies: 0
    Last Post: 04-02-2013, 07:02 PM
  4. Fan Shroud Clamp, 2 bolt vs. 1 bolt, 2.4 liter engines
    By caproader in forum Technical Info
    Last Post: 12-15-2010, 04:22 PM
  5. FS: Autopower Roll Cage - bolt in, bolt together
    By greggearhead in forum For Sale: 911 Parts
    Last Post: 06-17-2010, 01:01 PM
