Results 1 to 10 of 14
Thread: 901/82 gearbox
    Oct 2011
    California
    901/82 gearbox
    Can anyone give me some info on a 901/82 gearbox found in a 69S?
    Was told it was called airport gearing and there were only a few made that year.
    Appreciate any insights.
    Sep 2008
    Monza, Italy
    Hallo
    Yes, i confirm you that 901/82 ( effective from november 68, optional on type 911S) has special ratio for Airport races:
    1st: AA 12:34
    2nd: F 18:34
    3rd: J 21:31
    4th: O 23:28
    5th: S 25:26
    very close gear ratio. A rare and race oriented gearbox.
    the maximum speed at 7500 rmp is 195 km/h ( R&P: 7:31)
    Ciao
    Registry Member #1414
    NOSGRUPPE
    Restoration newbie.
    Jun 2007
    San Francisco
    I expect that would have a magnesium case, correct?
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Sep 2008
    Monza, Italy
    I have no infos about it.
    i suppose that it should be a 901/aluminium gearbox (push clutch) , not a 2,2 911/mag gearbox (pull clutch)
    but perhaps rmfent can say more....
    NOSGRUPPE
    Oct 2008
    Burford, ON, Canada
    If you have the box or access to it, then it really needs to be fully documented. I believe it is Mg case with serial in range 7392101 to 7392118. We need to have confirmation of case material, and the casting part #'s on the main parts of the case. It could have an F mainshaft or a 904 mainshaft with an F gear set; that would be interesting to know. LSD? Since it is so old, are the contents original or changed?
    Sep 2008
    Monza, Italy
    Interesting questions dave.
    the lsd should be there for sure.
    i'm here waiting....
    NOSGRUPPE
    Oct 2011
    California
    901/82
    Serial# is 7392103. Been told it is mag. Waiting on COA. Not sure about LSD as yet.
    Have not inspected inside as yet but will. Appears to be original to car as car was 1 owner.
    Sep 2008
    Monza, Italy
    Davep
    You are the man.
    Chapeau.
    NOSGRUPPE
    List of Transmission Types + Ratios . . .
    Quote Originally Posted by rmfent View Post
    . . . Can anyone give me some info on a 901/82 gearbox found in a 69S? . . .
    See the attachment for a summary of trans type #s and ratios --- courtesy of Bryce (beh911). . .
    . . . Not sure about LSD as yet . . .
    I ID'd the original fitting of an LSD on my car by looking for '|10' appended to the trans #, located on the bottom of the box
    HtH
    Oct 2011
    California
    901/82
    Will do. thanks for the info.
  1. WTB: 915 Gearbox
    By majordad in forum For Sale: 911 Parts
    Last Post: 07-24-2013, 01:08 AM
  2. Wtd-902/01 gearbox
    By rmfent in forum For Sale: 911 Parts
    Last Post: 08-25-2012, 05:36 PM
  3. FS 915 gearbox with 7:31 R&P
    By Erik@GBox in forum For Sale: 911 Parts
    Last Post: 04-24-2011, 02:38 AM
  4. Gearbox ID help
    By 911S1970 in forum Technical Info
    Last Post: 04-07-2009, 12:09 AM
  5. 915 Gearbox
    By cbk8 in forum General Info
    Last Post: 09-07-2005, 10:31 AM
