Results 1 to 7 of 7
Thread: WTB: 73 911 T front struts
    Looking for a set of front struts for a 73 911 T ! Thanks guys
    3 inch or 3.5 inch spacing?
    1974 MFI Carrera
    1992 Carrera RS
    S Reg #1245
    Oct 2008
    Burford, ON, Canada
    Standard would have been the 3.0" M calipers, and not vented I believe; so 3" struts.
    On a earlier purchase attempt I almost bought a set from an S car & that would not fit on the T so I'm pretty sure it's the 3" one that I need !
    Oct 2008
    Burford, ON, Canada
    There are several struts that will fit; the Boge T strut, the Koni S strut, the Bilstein S strut, and the Boge hydropneumatic S strut. The T strut can use the M caliper with either vented or non-vented rotors, and hubs to suit; the M caliper comes in both vented and non-vented forms to match the rotors. The S struts can use either the aluminum S caliper or the cast iron A caliper, and use the vented rotor with the appropriate hub. All you need to do is ensure that you get a matched set.
    My question is: what do you have now?
    Followed by: what do you want to wind up with?
    I would like to put the factory ones or as close as possible pretty much !
    Bought a set !! Thank you guys for all the great info !!
  1. Anybody know what front struts these are?
    By Nicklasliljegren in forum Technical Info
    Last Post: 01-13-2014, 05:59 AM
  2. WTD Pair front struts
    By timgt3 in forum Australia
    Last Post: 05-29-2012, 03:54 AM
  3. FS: SWB Front Koni Struts
    Last Post: 08-29-2010, 07:51 PM
  4. FS: RSR Front struts
    Last Post: 08-25-2008, 11:44 PM
  5. FS: RSR Front struts
    Last Post: 08-07-2008, 06:07 AM
