Results 1 to 10 of 11
Thread: Brake Cooling Kits Question
    less wing, more brass bxd's Avatar
    Mar 2010
    S.F. Bay Area
    AJ-USA used to sell a great 65-89 911 brake cooling kit for right around $300, but I just called them and they no longer make that kit. I know Pelican offers a kit, but the inlets are fiberglass, not aluminum, which to me seem pretty easily destroyed.
    Does anyone know of a brake duct cooling kit that is really well-made, maybe with aluminum instead of fiberglass bits?
    thanks,
    Jordan
    rally-prepped '69 911T 3.0L
    S Registry #1933
    Vintage Parts & Restoration http://retro-sport.com
    Senior Member C.Plavan's Avatar
    Mar 2005
    Clovis, Ca
    You could always buy 993 brake deflectors and attach them to the A arms. They work great on my race car, and are very, very cheap. ~$30 if I recall correctly.
    Chad
    911ST Race Car w/2.5L SS race motor.
    1972 911 T- Original numbers car- restoring it
    2016 Elan NP01 Prototype Chassis #20; Car Number #02
    2011 Porsche Spyder Wht/Blk/ Carbon Fiber Buckets (Sold)
    Powered by Faragallah (Aase Motors)
    Fiberglass brake cooling
    Well I think the fiberglass part has been given a bad rap. When asked "give me the 98.75% part or the 99% part" a racer will always say, "I'll take the better one". When translated into enthusiast speak....one is good the other is just plain crap.
    The record doesn't support that conclusion.
    I use to make the fiberglass cooling ducts and supplied a shop who fielded Daytona 24hr cars for over a decade. The fiberglass was used on my car for 22 years, that car has over 100,000 track miles. Never a problem.
    Think of the air shroud on the top of your engine - if it had been put on and not had buggered up mounting holes (mechanics?) my 49 year old part is still working just fine. It's moving air where it needs to be, it's not on the hot side of the air movement - it does not burn up...
    Yes the aluminum axel duct works perfect. But the fiberglass part was what Porsche used on the 908, 910, 934, 935, 956 (the list goes on).
    The important thing is to get air to the rotor, - any means possible is a good solution.
    Look around the market was saturated years ago. Used ones are out there.
    If needed for the quality of the build have your aluminum fabricator pattern after the photos here.. If you use aluminum, TIG is the way to go. Bucks and fabrication take time. Expect about $500 for the aluminum set.
    If you just need air - a pie plate and rivets will work for a weekend.
    Bob
    Early S Reg #370
    Fiberglass brake scoops
    Here are fiberglass brake scoops that had been in service for 22 years. Compared to a fresh set, a bit of road wear - sure thing, but "in place" and doing the job.
    No rant - just the facts.
    Bob
    Early S Reg #370
    Mar 2010
    S.F. Bay Area
    Bob and Chad, it's always good to get as much info as possible before pulling the trigger on this type of thing... and your input is fantastic, thank you.
    The kit on Pelican is the only one I've found online, and I do feel a bit tenuous about buying it, not simply because of the fiberglass bits, but because the one customer review on their site states that the quality of the kit is poor. Here is the review:
    Comments: The quality of the kit I received is very poor.
    The distribution plate required re-drilling.
    The picture shows a lower collect made of metal, the actual product is made of fiberglass, and the neck is very short and will not easily accept or hold the hose.
    2 hose clamps are missing.
    I intend to return the kit....very irritating for something this ridiculously expensive.
    Yes, pie-plates and zip-ties might work temporarily, but spending $400 on pie-plates is not what I am after
    Jordan
    S Registry #1933
    Mar 2010
    S.F. Bay Area
    Any more thoughts on this from anyone? Do many of you use cooling kits?
    Jordan
    S Registry #1933
    Feb 2003
    Corpus Christi, Texas
    Well sell the same kit with great success. I tell you what, if you buy it from us and don't like what you receive, I'll send you a call tag to bring it back to us.
    Jason Burkett
    Paragon Products
    www.paragon-products.com
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1972 911T
    1974 914 Limited Ed. Blk/Yellow
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    1968 Shelby GT500 Conv.
    2010 VW GTI, Daily Driver
    Feb 2003
    Also, the scoops on this kit are made of a very tough plastic, not fiberglass.
    Jason Burkett
    Paragon Products
    R Gruppe #375
    1973 911S
    1972 911T
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    Mar 2010
    S.F. Bay Area
    Thanks, Jason. What is the part number for the kit?
    Jordan
    S Registry #1933
    Feb 2003
    Quote Originally Posted by bxd View Post
    Here you go:
    http://www.paragon-products.com/Brak...-pbscbp78k.htm
    Jason Burkett
    Paragon Products
    R Gruppe #375
    1973 911S
    1972 911T
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
  1. WTB: Brake Rotor Cooling Block-off Plates
    By bxd in forum For Sale: 911 Parts
    Last Post: 01-07-2014, 09:04 PM
  2. FS: Front Brake Cooling Parts
    By Mr9146 in forum For Sale: 911 Parts
    Last Post: 12-19-2013, 04:53 PM
  3. WTB: brake cooling duct scoop
    By davewadd in forum For Sale: 911 Parts
    Last Post: 09-23-2012, 08:33 AM
  4. 911 Brake Cooling - The Early Years
    Last Post: 12-29-2006, 12:02 PM
  5. brake cooling ducts...
    By mjmoran in forum Technical Info
    Last Post: 04-08-2005, 09:56 AM
