Results 1 to 2 of 2
Thread: Bumper trim removal recommendations
    Jan 2013
    Montreal
    I am wanting to remove the trim front and rear on my original steel bumpers and re-paint for a cleaner look. Looking for recommendations on an easy/good way to plug the holes. Can I get away with body filler, better to use JB Weld and then finish with body filler or do I really need to weld plugs in. One of the reasons I would like to avoid welding is it would be easier to revert back if wanted. Thanks.
    1968 911T R.O.W. / 68S engine.
    My opinion is that any 'temporary' fix will eventually crack or fall out, the holes need to welded. However unless you finish the back side you'll be able to spot the welds to drill out, or better yet just find another bumper to weld up saving your original in case you get customizers remorse
  1. FS: Early 911 Front Bumper Trim + Rocker Trim
    By METAVINYL in forum For Sale: 911 Parts
    Last Post: 12-04-2013, 10:09 AM
  2. 72 bumper removal question
    By 313green in forum Technical Info
    Last Post: 03-21-2011, 07:19 PM
  3. FS: Parts from a 70T Bumperetts Bumper Twin Tube Bumper Trim
    By 76911S in forum For Sale: 911 Parts
    Last Post: 08-30-2010, 02:52 PM
  4. 0 for 2 today. Need help with front bumper removal.
    By ulrichd in forum Technical Info
    Last Post: 08-12-2007, 10:11 AM
  5. Dash trim removal
    Last Post: 03-30-2007, 07:37 AM
