Results 1 to 10 of 11
Thread: 73 911 T oil cooler question
    I have a question about the oil cooler for a 73 911 T targa ! After removing the fenders I didn't see any oil cooler mounted anywhere ! Can you guys help me out with this ? I'm not a 100% sure what is it supposed to look like so If you have some picture where is it supposed installed at ? Thanks guys
    under right front fender, it was an option only.
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    The oil cooler is mounted on the motor unless it has the optional front ( inside right fender ) cooler
    T's usually don't run hot unless they are modified....
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    Thank you for the info !! Great help
    In case a few pics help here is an external cooler set up on a 73 T we are restoring. The cooler is a one year only part, we make these as well as the long lines.
    HTH
    Alan
    And you would see two pipes running along the bottom edge of the right side of the car, below the door, that goes to this trombone up front.
    Feb 2010
    San Francisco, CA
    And of course the '73 specific external thermostat and associated pluming.
    Be prepared to shell out some $$$
    Keep in mind that this was a somewhat rare US option on a T. Unless its on your COA or you want a period exact system, there are other (some argue more functional) cooling options.
    E911SR & RGRUPPE
    '73 S Coupe #306
    Thanks guys all great info
    Dallas, TX
    Great pictures. Are their any indentations or markings in the sheet metal that indicate where to make holes under the car for the oil lines under the rocker panels or up in the wheel well? This is for a '73 as well.
    Neil
    Neil
    '73 911S targa
    Alan,
    What is the cost for the replica cooler and long lines? Any idea how costly shipping would be to the east coast of US?
    Mark
    Mark Curtin
    Early S Registry #369
    Rgruppe #247
  1. Oil Cooler Air Flow Question
    By jameshtaylor in forum Technical Info
    Last Post: 10-23-2009, 06:37 PM
  2. S oil cooler .. trivia question
    By preS in forum Technical Info
    Last Post: 09-17-2009, 09:58 AM
  3. oil cooler upgrade question
    By robmog in forum Technical Info
    Last Post: 02-11-2008, 05:44 PM
  4. '73 Front Oil Cooler Question
    By ennisk1 in forum Technical Info
    Last Post: 07-30-2007, 05:54 PM
  5. Front Oil Cooler Question
    By CamBiscuit in forum Technical Info
    Last Post: 07-24-2006, 03:03 PM
