Results 1 to 10 of 12
Thread: What is this relay for?
    Apr 2011
    N.Calif., south of SF
    Part # 91161510901
    Name:  Screen Shot 2013-05-27 at 9.49.44 AM.png
    It is located by the fuses in the trunk (lower left in picture below)
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    1969 S Coupe #761
    Early S Registry #1624
    Feb 2010
    San Francisco, CA
    Beat me to it. I was going to say horn also.
    Here's the pic from the thread mentioned above.
    E911SR & RGRUPPE
    '73 S Coupe #306
    Apr 2011
    Thanks .... interesting thread in how it progresses over three pages.
    I did realize that the horn(s) stopped working yesterday. Thanks, I'll try and figure it out.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    That's a 'universal' relay, used for a number of different functions, horn being one of them.
    Apr 2011
    Thanks for the replies. Interesting in the myriad of electrical events, the horn quite.
    I've been trying to solve-
    -brake lights come on when lights (parking & headlights) are on
    -Turn signal indicators in tach both illuminate when using left or right blinker
    -replaced failed headlight switch
    So far I-
    -replaced rear light housings (OEM), cleaned & restored front turn signal housings
    -replaced all the fuses in the trunk with copper style instead of aluminum
    Yes, of course grounds, but I will check all the housing grounds again, but I did clean and use dielectric grease on all contacts.
    I have noticed that the new rear light housings are not making excellent contact with the bulbs, that surprised me. I guess I need to bend the bulb connector contacts more.
    Oh these electrical gremlins! Starting to try my patience!
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    I've had poor experience using dielectric grease on contacts, I mean after all it is supposed to inhibit electrical transmission. I prefer a light coat of WD40.
    Apr 2011
    David, was just thinking about that. Maybe I'll go back to ye 'old WD40 and start there. Maybe the grease actually is inhibiting good conductivity.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Aug 2009
    Atlanta
    Quote Originally Posted by Haasman View Post
    I had the same problem and after going through all grounds, I replaced the flasher relay and it did the trick (found behind instruments, inside trunk). Got it from Pelican:
    Horn quitting could be a red herring, unrelated to other issues. Try swapping a known good relay and see if that fixes it
    1969 S Coupe #761
    Take your tail light housing out, and using a 12 v test light verify that you are getting the proper signals at the right color wire when lights, turn, and brake are applied.
  1. WTT: MFI Relay for MFI Relay (see part numbers in ad)
    By denson in forum Free, Trades, and Swaps
    Last Post: 12-29-2013, 05:31 AM
  2. WTT: MFI Relay for MFI Relay (see part numbers in ad)
    By denson in forum For Sale: 911 Parts
  3. Help me id this relay.
    By merbesfield in forum Technical Info
    Last Post: 07-25-2012, 01:33 PM
  4. looking for MFI relay
    By EARLY911ZOO in forum For Sale: 911 Parts
    Last Post: 07-08-2009, 01:02 PM
  5. WTB - MFI Relay
    By mike curnow in forum For Sale: 911 Parts
    Last Post: 07-04-2009, 05:28 PM
