Thread: Car went dead in the middle of the road
    They say timing is everytning,,,,, Memorial Day was not an easy day to get a flatbed. So, I filled the tank up, drove 1/16 of a mile and dead. I doubt it is the gas, even through timing is dead on. The car was running great and just went completely dead. I can smell gas at the engine bay after truning it over and it sounds very healthy. So, now I am thinking spark. Can you just lose spark like that,,,, boom dead?
    If it is about the spark, does the coil matter in this instance, and where else would I go? Any ideas? This is for a 1790 S.
    RGruppe member 445
    Apr 2004
    35,000 ft
    Coil and CDI box, points, all the basics, and make sure all the wires are attached to each....spark is easy to diagnose, grab a rag, and/or heavy pair of gloves, pull a spark plug wire an inch off its plus and listen for a snap snap every rotation of the motor. I'm happy to lend a hand if you need it, you've got my email.
    I had a couple colils do that to me. A vw beetle coil from your local Pep Boys will get you home in a pinch and is a cheap way to rule it out.
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    I had a feeling it was the coil and luckily had a good used one in the parts bin. The car started right up.
    Thanks a lot guys for jumping in and helping out!
    RGruppe member 445
  1. In the middle of a job speedo drive question
    By Rich Lambert in forum Technical Info
    Last Post: 04-10-2013, 09:47 AM
  2. WTB: LWB 911 roller WANTED DEAD OR ALIVE - Preferably dead!
    By lexatola in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 12-29-2012, 08:26 AM
  3. WTB: Parcel Self and Rectangular Middle Piece for a LWB
    By RickS in forum For Sale: 911 Parts
    Last Post: 12-21-2012, 08:34 PM
  4. Oil leak in middle of oil cooler
    By red911 in forum Technical Info
    Last Post: 07-07-2012, 03:11 PM
  5. '65, '66, or somewhere in the middle?
    By Demetri in forum General Info
    Last Post: 05-06-2011, 05:51 PM
