Thread: Rear wiper delete -- plug??
    I'm thinking of removing the rear wiper assembly.
    Was there a "plug" in the hole if the cars came without a wiper originally???
    Are the grills different?
    My impression is the engine lids and everything else was identical on cars with and without wiper and that it was essentially an "add on".........is this correct?
    This is for a 70 911T
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Don`t know of any plugs...doubt they exist......ingenuity must be exercised on your part...Cliff
    Engine Lids + Wipers
    Quote Originally Posted by nikojo View Post
    . . . thinking of removing the rear wiper assembly . . . My impression is the engine lids and everything else was identical on cars with and without wiper and that it was essentially an "add on".........is this correct? . . .
    Uhhhh --- NO . . . and YES
    NO --- in that, all engine lids prolly started out the same . . . but, once a wiper got fitted --- there's no turning back
    1) Original Porsche (alu) lid, fitted w/ factory wiper. If you look closely at the upper left grill tab, you'll see a bushing that takes the pinion for the wiper arm
    2) Underside of above, showing the rear wiper install
    3) Original Porsche (alu) lid. If you look at the same upper-left tab, as 1), you'll see no hole or bushing for a wiper
    There may be a 'plug' of some kind used --- whenever someone de-commissioned the wiper . . . but it would've been done after-the-fact, not standard, so . . .
    YES --- the wiper install is an 'add-on' . . . option code 425 for your 1970 . . .
    . . . mine, too! --- see post #434
    http://www.early911sregistry.org/for...ty-nine/page44
    HtH
    you guys are awesome.
    thanks for the great responses and pics.
    hope i can return the favor sometime.
    'Spacer tube'?
    Another interesting thread --- w/ pics --- see post #47 . . .
    http://www.early911sregistry.org/for...d-Trivia/page5
  1. FS: Rear Wiper Motors, Mounts & Wiper Arm
    By jaudette3 in forum For Sale: 911 Parts
    Last Post: 10-01-2013, 01:10 PM
  2. FS: Clock delete plug
    By javadog in forum For Sale: 911 Parts
    Last Post: 12-19-2012, 07:42 AM
  3. clock delete plug
    By Rico in forum For Sale: 911 Parts
    Last Post: 09-18-2009, 05:29 AM
  4. WTB: Clock delete plug.
    By Macroni in forum For Sale: 911 Parts
    Last Post: 06-24-2008, 08:34 AM
  5. RS Rear Seat Delete
    By thorsten73 in forum General Info
    Last Post: 04-05-2005, 08:23 AM
