Thread: Deco trim question
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    Deco trim question
    Here's a couple pics of the bumper deco trim on my '70 911T that I recently bought. Not sure what's going on here?
    Here the deco trim on the rear drivers side stops short of the reflector. Not sure what's going on here? Why the gap? How do I fix this?
    Here's a shot of the front section of the same deco trim. Is there supposed to be a split in the rubber? Thanks
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    The rubber has shrunk.
    If it's new, are both the rubber and alloy trim new? If so it's a manufacturing fault, as you can't slide the rubber any further around, due to the mounting screw that's in the end, as you probably know.
    Tony
    Nov 2006
    S. F. Bay Area
    Shrinkage!
    It looks as though time has done it's deed, as the small, rubber base trim has also retreated in the front. Yes, the "split" is a joint, the tapered end has a metal retaining 'stud' integrated to prevent the front tapered end from doing what yours has done by the reflector.
    Brian
    S Reg #1032
    229 MPH 3.0 MFI 911
    Feb 2011
    Arizona
    It looks like older shrunken rubber on the rear deco. There is a bonded seam on the front on both sides. If your rubber has split at the bonding it will need replacement.
    Sep 2012
    Toronto
    Thanks guys. Who knew rubber could shrink!
    The old plasticizer in the material volatilizes and evaporates over time, shrinking the rubber, kind of like a raisin compared to a grape. Newer polymers and plasticizers are more stable these days, so new material should last longer than original.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. FS: NOS rocker deco rubber 1968 - 1973 and deco trim hardware
    By IAA1963 in forum For Sale: 911 Parts
    Last Post: 02-02-2014, 10:34 AM
  2. FS: Rear deco trim
    By Bob Harriman in forum For Sale: 911 Parts
    Last Post: 10-11-2013, 03:19 PM
  3. 67S Rocker Deco Trim
    By Larryg57 in forum For Sale: 911 Parts
    Last Post: 12-27-2008, 11:25 AM
  4. looking for 67S rocker deco trim
    By EARLY911ZOO in forum For Sale: 911 Parts
    Last Post: 05-16-2008, 09:22 PM
  5. RS Deco Trim
    By GI60S in forum General Info
    Last Post: 08-25-2005, 05:43 PM
