Results 1 to 8 of 8
Thread: Rear suspension crossmember 901.501.075.21
    Jul 2012
    Kent, UK
    Hello,
    So after a year of restoration, sandblasting the underside reveals significate rust damage to turrets, When turrets are rusted, what do people do? Fabrication, salvage from donor? Can later chassis 911.501.075.07 be used/ modified?
    Thoughts / help please.
    Rich
    Rich
    68 911S
    mbr. 2393
    Dec 2010
    Tulsa
    Yes you can use a later one. I replaced the crossmember in my '70 with one out of a '74- it has larger shock openings and a slightly different angle, allowing use of aluminum trailing arms and coilovers. I'm pretty sure that it works fine with the stock suspension as well.
    Wait, the original poster has a '68, correct? If so, then he can't use the post 1968 piece without also converting to long wheelbase!
    edit: Sorry, I was thinking of the torsion tube, not the crossmember where the dampers mount. If I had a 1968, though I would not count on anything other than a 1968 crossmember fitting, or at least a short wheelbase one.
    Dec 2010
    Tulsa
    You're right - I didn't see that in his signature. I know that they can interchange on LWB cars, but I don't know about his '68; somebody check PET
    Dec 2008
    Black Mountain, NC
    I have a 68 912 swt that if I cant get rid of the rest of the chassis I would cut this for you if needed. I will also ask a friend in town who may have one cut from a 68.
    drop me a note with contact info if interested.
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Jerry, I could use a section between the gas tank & gages. Someone in the past cut two holes so they could mount speakers towards their feet. Let me know if you can accommodate. Mine is a 67 Porsche built 912.
    Thanks Cliff
    Jul 2012
    Kent, UK
    Has anyone got any pearls of wisdom regarding re fabrication of turrets on the crossmember?
    Thanks Rich
    Rich
    68 911S
    mbr. 2393
    Oct 2005
    wash dc/ los angeles ca
    If I understand you correctly your referencing the shock towers if these are rusted out you can likely have some removed from a donor and reinstall in your
    car the trick is likely cutting an access from the interior by opening the panel above the seat pans.
    Similar work is often done to race cars or Turbos needing adjustable rear arm mounts ,some leave the panel removeable for easy access ..not necessary in
    your situation...Bert
    Oh and I would love to get a look at your '68S ,I have one as well #513 Blood Orange Twin Plug thanks Bert
  1. FS: 69-73 Rear Torsion Crossmember - OEM/NLA Part
    By FrankT in forum For Sale: 911 Parts
    Last Post: 02-06-2013, 02:29 PM
  2. Is there interest in this rear crossmember reinforcement?
    By mscott842 in forum Technical Info
    Last Post: 12-16-2010, 11:04 AM
  3. WTB 911 Rear Crossmember Engine Rubber-Seal Rail-Guide
    By 914-6gt in forum For Sale: 911 Parts
    Last Post: 11-03-2006, 07:14 PM
  4. RS rear suspension
    By 911pcars in forum General Info
    Last Post: 11-02-2004, 11:15 AM
