9113300709 Low Oil Pressure Issue
Background: I acquired this 73S this past summer. The car has 100k miles on it (I believe to be accurate). I was told it has a 2.8-liter motor. The MFI pump space cam was recalibrated by Pacific for 2.8 and installed by Canepa.
I haven’t pulled the plugs to check for heat range/correct specs, but I did check the timing and adjusted it from 3 to 5 ATDC. This BTW cured spitting in the intake at idle.
It is a very fast car, a screamer with a tractable engine that pulls easily from just above 2,000 RPM. I’ve been working through a lot of issues including interior, suspension etc, but in all a wonderful very fast car.
The car lives in northern California, in a temperate area so until yesterday I hadn’t driven it in temps greater than high 70 degrees. Yesterday after going to EASY in Oakland, the temperatures were in the high 80s to low 90s. This is when I saw the oil pressure plummet. The car is running Brad Penn 20W-50 partial synthetic that was replaced a week ago. It has a Porsche parts filter.
A side note: I replaced the oil pressure sending unit thinking that was the culprit, and also tightened the OP sending unit mount with correct crush washers, since there was evidence of oil seepage. No change.
When starting the engine cold with ambient temps of approximately 55 degrees the oil pressure is just under 100 PSI (per the dash gauge) and this seems normal to me.
As the car is driven and the engine temp comes up to just below 180 degrees the oil pressure starts to lower, and this I would also expect to some degree. Up until yesterday the rough ratio of 10PSI per 1,000 RPM was pretty close, but still seemingly a bit low at 60 PSI at 3,000 RPM.
Then yesterday with the ambient temps climbing to the low 90s is when the pressure got very low: just above 20 PSI. This scared me. Since I was at the top of the coast range where the weather will be cooler I carefully drove (low RPMs) until the ambient fell to the mid 70 degrees again. It never got below 20 PSI but as I slowly moved closer to cooler ambient temps (coast) the engine temperature came down and the oil pressure improved a bit.
The engine hasn’t gone above 220 degrees, it seems it the oil pressure that is the issue.
Does this ring a bell with anyone? I have search through and read many, many threads on this forum and on The Bird.
Unsure how to proceed. Suggestions and recommendations greatly appreciated.
Additionally- I do have a trombone-style loop cooler but would need to source the hoses and hardware to install it.
Cold start-
Yesterday was a hot day-
