Results 1 to 2 of 2
Thread: Beru spark plug connector
    Senior Member bobm's Avatar
    Aug 2011
    Northern California
    I have a 1966 2.0 and a friend gave me 6 brand new Beru # 911.602.315.00 connectors. The info I find show them for 74 YM and up. Can these be use on my 66 2.0 motor.
    I am not sure how the wires go into the connectors as there is no wood screw inside. Is there a end piece that is used to attach the wire and connector?
    He also gave me a bag of WSP-M# brass threaded ends, not sure how they attach either. I don't know the age of the current wires, I looked at and tested the wires and they seem fine.
    The a couple of the current (wood screw) connectors look a little suspect (burnt).
    Sorry if this is elementary , but I could not find info on this list or on the bird.
    Thanks for any help.
    Bob
    Nor Cal.
    Those are the later right-angle type which will work but are not what originally came on a '66.
    They attach with an M3 brass connector which is crimped to the wire.
    You can buy the proper crimper from Kingsborne although it would be better to borrow it!
    http://edelweiss.smugmug.com/Cars/Po...7752&k=LNgPStP
  1. FS: NEW set of Beru Stainless Braided Spark Plug Wires
    By hwgunner in forum For Sale: 911 Parts
    Last Post: 06-14-2013, 08:03 AM
  2. FS: Plug Wire Set and Ends OEM BERU
    By jhora in forum For Sale: 911 Parts
    Last Post: 01-19-2013, 05:18 PM
  3. Spark Plug Wires with Beru Fasteners and Rubber Seals
    Last Post: 05-07-2010, 07:27 AM
  4. 2.4S spark plug
    By cosley in forum Technical Info
    Last Post: 07-27-2007, 08:42 AM
  5. What's the right spark plug to use in a 2.7RS?
    By JimR in forum Technical Info
    Last Post: 06-11-2005, 05:12 PM
