Results 1 to 8 of 8
Thread: MFI Fuel Lines- looking bad
    Apr 2011
    N.Calif., south of SF
    The steel fuel injection lines on the 73's MFI are starting to gather some surface rust. Any suggestions on how to clean and brighten them up? Does it make more sense to replace them? <--- or is that ju$t too costly?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    I cleaned mine with WD-40 using a mild scrub pad like the kind for dishes. On occasion I have to apply WD-40 again with a toothbrush as wax never seems to hold up.
    000 steel wool
    -Marco
    TLG Auto: Website
    I agree with both.... WD-40 on 000 steel wool
    Apr 2011
    Great, thanks for that. If I were to remove each one to clean them, would I need any crush rings etc?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Quote Originally Posted by Haasman View Post
    You may need some stack gaskets ... stacks will need to come off to get 1-2-3 lines off.
    -Marco
    TLG Auto: Website
    Oct 2005
    wash dc/ los angeles ca
    I just this week removed both banks of MFI lines ,had them bead blasted and zinc coated then reinstalled ..look like new ,and no need to remove the stacks
    on either side, Bert
    We also replate them, but I wouldn't leave the ends open. We made up some plugs to stop the solution going I side the lines.
  1. Fuel lines
    By 71-911T in forum Technical Info
    Last Post: 01-10-2014, 09:34 AM
  2. replacing fuel lines: hoses and metal lines, 1967
    Last Post: 07-10-2013, 05:28 PM
  3. Replies: 3
    Last Post: 03-09-2013, 08:14 AM
  4. Fuel Lines
    By garycox in forum Technical Info
    Last Post: 03-29-2010, 11:14 AM
  5. Where to buy fuel lines?
    By JimR in forum Technical Info
    Last Post: 04-11-2005, 09:21 AM
