Thread: Correct size of rear stabilizer/sway bar?
    Senior Member npvpositive's Avatar
    Dec 2012
    Sydney, Australia
    My 71S has a non-stock rear sway bar that I want to bring back to OEM. Can anyone confirm whether 15mm thickness is correct OEM size for a 1971 2.2S?
    The Porsche Classic catalogue seems to indicate that 15mm (901.333.701.04) was standard across all the models (T/E/S/2.7) but I'd hate the order the wrong one. There seem to be after-market (Weltmeister) bars available in a whole range of thickness from 15mm-22mm.
    Nick
    Nick
    1971 2.2S, Bahia Red
    Early 911S # 2534
    TYP901 # 264
    Porsche Club of NSW
    Jan 2011
    DFW TX
    Per the Technical Specifications book, 15mm is correct. Std on S, optional on T/E. Depending on what you have now you may prefer the handling with the identical looking factory 18mm bar.
    In my experience the Weltmeister bars work, but they don't look right.
    Dec 2012
    Sydney, Australia
    Thanks Mike, much appreciated!!
    Nick
    Early 911S # 2534
    TYP901 # 264
    Porsche Club of NSW
  1. Correct wheel stud size for 1973 911T coupe?
    By Paul-HB in forum Technical Info
    Last Post: 06-17-2013, 12:46 PM
  2. correct pully size for a 68
    By preS in forum Technical Info
    Last Post: 10-10-2012, 05:02 AM
  3. Correct tire size
    By Varooom in forum Technical Info
    Last Post: 11-05-2009, 12:42 PM
  4. correct tire size for 1972 911T
    By Perry911 in forum Technical Info
    Last Post: 01-11-2009, 04:11 AM
  5. 1971 S F/R Sway Bar Size???
    By sam71TargaS in forum Technical Info
    Last Post: 12-14-2006, 07:05 PM
