Thread: 1967 911S connecting rod i.d. needed
    Nov 2006
    S. F. Bay Area
    Carefully weiged all rods with bolts/nuts, and 1 turns up 39g heavy. The other 5 are within 2 g. of each other.
    The one heavy rod has casting#: 901.103.101.0R followed by a small "s" inside a larger "U" shape. The cap is 901.103.111.0R. The cap and rod stamps match.
    Is this even a correct '67S rod?? Thanks
    Brian
    S Reg #1032
    Brian, I think the reason for the weight discrepancy is that the one rod is from a different set. The "S" rods were nitrated and look like this:
    whereas the normal rods (mine) look like this with the mark you mention:
    There is no difference (other than the nitrating) between the rods, it's just that you got one from a different set and therefore weight group. See if you can get an "S" rod to match and then send the whole set to be rebuilt and matched to within a tenth of a gram.
    Nov 2006
    S. F. Bay Area
    Thanks for the info. I just got them back from Ollie's and was just checking on the scale...I think they may have forgot to balance the set, I'll call tomorrow. Brian
    Brian
    S Reg #1032
    i have spare 67S rods, balance them end for end meaning each end is weighed in a horizontal position. the big end is rotating mass like the crank, the little end is reciprocating mass like the pistons.
    Nov 2006
    S. F. Bay Area
    Wow. Old thread, but good replies, thanks. (304065-smart boy!)
    Turns out the machine shop had mixed in 1 rod from another engine. Oops, things happen. They sent my wayward rod back to complete my matched set. They are installed awaiting motor completion. Again, thanks.
    Brian
    S Reg #1032
  1. WTB: A few parts needed for 1967 911
    By Silverbullit in forum For Sale: 911 Parts
    Last Post: 11-02-2013, 09:38 AM
  2. 1967 911S flywheel identification help needed:
    Last Post: 06-01-2013, 02:05 PM
  3. 2.0 Liter 911S connecting Rods
    By leecarrera in forum For Sale: 911 Parts
    Last Post: 10-09-2012, 08:29 AM
  4. WANTED; WTB 1967 911S with incorrect engine or 1967 rolling chassis
    By almostblue in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 01-15-2012, 05:43 PM
  5. 1967 911s & 1967 911s rolling body shell to trade
    By RJ Schwartz in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 05-20-2010, 03:52 PM
