Thread: Help sporto gear problem
    Hello
    i 'm restoring a 911 L 1967 sportomatic MY68.
    i have a problem with the gear. i changed the clutch and pressure plate, the clutch realease bearing, all the seals and the synchroniser rings.
    the 1st and the rear gears don't work, the others work.
    i can change the 1st and the rear if the the motor is off.
    Do you know the problem is?
    Sorry my english... i hope you understand me
    Thanks for your help
    Aug 2012
    France
    Quote Originally Posted by RANGELOVER View Post
    Hello
    Based on a french Forum :
    911 L 1968 - Sporto
    While the engine is on at idle, all the gears can get engaged, but the 1st and the reverse. While the engine is off (turned off) the 1st and reverse can get engaged smoothly.
    I do not know the sporto, as a Vulcan coud it be anything with the fact that the reverse and 1st gears have not synchro ? Therefore the mecanism to engage those is not working properly, meaning the issue is not with the sporto(clutch) system but rather within the gearbox, as the other synchro gears are ok ?
    my 2 cents.
    O-G 26 - Early911S 2407
    All the syncro are new
    Aug 2012
    France
    I meant there is no syncrho at all for reverse and 1st, so the mecanism to engage the 1st and reverse are maybe faulty ?
    Il n'y pas de synchro sur la marche arriere et la premiere il me semble, c'est donc peut etre le mecanisme d'engaement qui ne fonctionne pas correctement, puisque lorsque le moteur est en route, ces deux vitesses ne passent pas.
    mais si la boite est totalement revisee...
    juste mon conseil a deux balles.
  1. Replies: 11
    Last Post: 05-16-2013, 05:29 PM
  2. WTB: B 1st gear and GA 2nd gear for 901 transmission.
    By RSwannabe in forum For Sale: 911 Parts
    Last Post: 01-20-2013, 10:25 PM
  3. WTB gear sets for 911/01 gear box
    By 60surfer in forum For Sale: 911 Parts
    Last Post: 05-31-2009, 09:27 AM
  4. 68 Sporto Coupe, 72T Sporto Coupe, 73.5T Targa & 82 930 Turbo for sale
    By mschnittker in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 03-04-2007, 09:36 AM
  5. 1968 911S Sporto Wiring Problem
    By AP911S in forum Technical Info
    Last Post: 05-26-2001, 03:48 AM
